Old 03-08-2007, 04:35 PM   #1
Is this circuit possible?
Hi all,
Please forgive what may be a silly question, but I'm trying to add some undercabinet lights - this diagram may help...
Where exactly does the switch get connected to the main line from the panel that controls those 2 outlets? Do I add a box in the basement?
Thanks,
Sean
webguy is offline   Reply With Quote
Old 03-08-2007, 04:57 PM   #2
Originally Posted by webguy View Post
Hi all,
Thanks,
Sean
Have you purchased the undercabinet lights yet?
They sell undercabinet lights that already have a small on/off switch on them.
redline is offline   Reply With Quote
Old 03-08-2007, 05:02 PM   #3
The kitchen counter top recepticle circuit is not allowed by code to serve any other loads. Under cabinet lights included.
Catch 22 is that if you install extra recepticles on the kitchen counter top, they are by defination "kitchen counter top recepticles" the code specs a minimum number not a maximum number.
So, cord and plug connected undercabinet lights will not work at all.
Master Electrician
jwhite is offline   Reply With Quote
Old 03-08-2007, 05:21 PM   #4
Well there it is then - thanks for your reply
The wife desperately wants the undercabinet lights controlled by a switch on the wall, so this is no longer a DIY project. Best left to the pro's...
Sean
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
Circuit configuration??? Clutchcargo Electrical 11 05-30-2007 09:01 AM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 09:26 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
