Circuit Panel Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-07-2009, 01:43 PM   #16
Originally Posted by spark plug View Post
This poster (me) suggested earlier to look for a manual reset switch around the Hot Tub. Apparently this will not be solved despite the best efforts of everyone (except the dealer) involved. To do the right thing, --after the fact-- the dealer should send a technician to the house. On another level. The manufacturer should have a "Hot Line", manned by professionals to guide a New customer through the starting process. (No matter what)Don't Drink and Drive, Ever!!!
Sorry, I missed that. I just skimmed the posts. I would at least make sure power was getting to the hot tub before I go calling the manufacturer. That will be the first question they ask.
jerryh3 is offline   Reply With Quote
Old 10-07-2009, 01:56 PM   #17
Thumbs up
I will respectfully disagree with you. When someone buys a big-ticket item, where comprehensive technical details are involved they expect it to work smoothly without any problems, at least initially. The dealer is best equipped to handle any problems that may arise. Either through their own employees or independent technicians authorized by them. (IMHO)! (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 10-07-2009, 03:03 PM   #18
Licensed Pro
Turn the breaker with the test button completely off (handle all the way to the right). Pull out the red piece that has the handle at the hot tub disconnect and set it aside. Turn the breaker back on (handle to the left). Does it go all the way on? Does the test button now work? If the answer is yes, the problem is in the tub. If the answer is no, the breaker is bad.
Old 10-07-2009, 03:18 PM   #19
What if there was a ground fault in the disconnect?
Electrical Panel "cut-in" question Todd-sta Electrical 52 12-03-2008 11:07 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Next Question, Sub panel in detached garage... OmegaBunny Electrical 5 09-15-2008 11:37 PM
Quick question: No ground bar in panel? dawho1 Electrical 3 04-06-2008 10:17 AM
Main panel design question amakarevic Electrical 13 06-04-2007 04:35 AM
