Circuit Out But Circuit Breaker Didn't Trip - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2008, 07:25 PM   #16
Paul
It ended up just being that the fixture wasn't connected properly. I had a ***** of a time getting it connected. The wires were so thick, unbendable and short and I couldn't even get one, let alone all three, under the screw as you are supposed to.
They provide a hole with a spring-loaded metal piece that they say you can use as an alternative, with space only for one of the three twisted wires. I used that. One of the wires was loose.
It simply did not occur to me that it was even on the same circuit. And, even if it was, I thought I eliminated this kind of thing by noting that the light fixture actually worked.
I hired an electrician who re-wired the light fixture and said it was just flaky and vibrations could make it work sporadically. But what I saw was the light fixture always worked and the rest of the circuit never did. Weird!
Paul
PaulenAndrew is offline   Reply With Quote
Old 08-14-2008, 12:34 PM   #17
When is fishing season?
CowboyAndy's Avatar
Paul
Unless specificly designed for it, only 1 wire per screw. You should take the fixture back down and use wire nuts. Take a short piece of wire and wire nut it to the rest of the wires, then attach that short piece (pigtail) to the screw.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 08-16-2008, 08:38 AM   #18
Paul
Thanks. Then why the heck do they make 3 live wires?
I don't know about wire nuts. Are those the things that are like a plastic cap? Honestly, I don't understand what you're saying. Do you have a picture? A separate/new length of wire?
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 04:40 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 02:44 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
