Which Circuit For My Garage A/C? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 10:00 AM   #16
Rewards Points: 322
pic fbox
Here are the circuits all running into the house through one hole. Wondering how one adds a circuit to go the the garage?
puttster is offline   Reply With Quote
Old 05-09-2012, 10:16 AM   #17
Rewards Points: 204
Are you certain you know what "detached means". That the garage does not touch the house in any way. It shares no roof with the house. There is no breeze way either. Is this correct?
If the garage is detached you can use one of those open KO's (holes) on the bottom of that service panel.
You do not try and use the opening where all those cables go into the house. Pick a hole in the bottom and run your single circuit, MWBC, or feeder to the DETACHED garage. Your garage is not compliant and not up to code if more than one circuit is going out to it.
Ps..........If you do not use the open holes (KO's) in the bottom of the panel, get some KO plugs and cover them up. They snap right in. Whomever did this work should lose their license if they had one to start with. Or you do not have the ability to describe your issue. Its one or the other. That panel outside like that is very common in my part of the country and I despise it. Are you in SC or the south?
Old 05-09-2012, 05:41 PM   #18
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
That's not a panel it's an image of an electricians nightmare.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
gregzoll (05-09-2012)
Old 05-09-2012, 06:45 PM   #19
Rewards Points: 322
I see what you're saying. Don't mess with the big hole, screw some conduit/PVC up to the bottom of the box using locknuts and feed the cable in there. Forget the holes in the back of the box?
Old 05-09-2012, 07:34 PM   #20
Rewards Points: 6,652
rrolleston, I wonder what it would measure, if someone took a F.L.I.R. to that mess. Definitely beyond capacity for that 2" piping.
Old 05-09-2012, 07:43 PM   #21
rrolleston's Avatar
With a decent load throughout the house maybe a pretty red spot right at the stuffed pipe.
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Hallway and garage on same circuit - NEC 2005 fuzzball03 Electrical 10 12-13-2011 09:46 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Circuit Problems - Garage DisturbedPanda Electrical 9 08-03-2007 09:23 PM
