Circuit Layout - Electrical - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 03:07 PM   #1
Rewards Points: 172
Circuit Layout
Hello:
I know I have asked different questions regarding some work I am doing and have gotten many helpful responses. I just laid out a diagram of what I am doing and want to make sure everything is ok.
Currently, I have a 20 Amp circuit running to a 2nd floor bedroom that only powers 2 outlets and a ceiling fan (Becasue of a converted kitchen). I wanted to add another ceiling fan in the bedroom and lights in 2 other bedrooms and figured it would be best to tie into this circuit since I have access from the attic. And since I am up there, I was going to add smoke alarms to each bedroom as well.
Here is the diagram of what I am doing. Is it ok?
zephed666 is offline   Reply With Quote
Old 04-20-2011, 03:23 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
do your smoke alarms have to be interconnected with some other smoke alarms already installed?
Old 04-20-2011, 03:27 PM   #3
Rewards Points: 172
I just have battery operated smoke alarms throughout the house. Figured I'd put the wired ones in upstairs while I'm in the attic and interconnect them.
Are there any issues with the layout?
Old 04-20-2011, 05:06 PM   #4
Rewards Points: 760
The layout does look good but...
Check with your wiring inspector. In some locations the smokes have to be on their own circuit. You may also need to upgrade to an AFCI protected circuit in the bedroom depending upon the version code your locality uses.
AandPDan is offline   Reply With Quote
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Planning circuit layout for barn tbeaulieu Electrical 8 04-08-2010 09:38 AM
Circuit tester shows open neutral; multi-meter says something different. fredgmeyer Electrical 11 10-26-2009 12:41 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Replacing a circuit breaker tertius Electrical 9 09-24-2009 08:17 PM
