Circuit Dead Without Tripping Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 08:13 PM   #1
Circuit dead without tripping breaker?
My son was using a shop vac to clean up a mess in the basement, when the basement lights went out, and the vac stopped working.
A quick check revealed nothing out of the ordinary on the breaker panel, and cycling the breaker doesn't fix the problem. Any hints or tips?
The other receptacles work just fine - they are on a separate circuit. The circuit in question has only the basement lights and 2 receptacles, both of which are also dead.
Shop vac works fine when plugged into a receptacle on another circuit.
I'm...clueless. Any suggestions as to where I should start looking?
rpfeinman319 is offline   Reply With Quote
Old 03-20-2010, 08:36 PM   #2
Master Electrician
Rewards Points: 3,920
Tripped GFCI?
brric is offline   Reply With Quote
Old 03-20-2010, 08:56 PM   #3
DAMN it! lol Let me check. No, but I like the way you think!
Can't believe I didn't check that first. Reset, test, reset with no changes.
Old 03-20-2010, 09:02 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
although it would not be my first suspicion but would be among the first things checked; it may be possible to have a bad breaker. If you can actually check the voltage at the breaker, it would eliminate that possibility.
after that, I would suspect a bad connection. If you have back stabbed receptacles in the house, I would suspect a bad connection in one of the receps terminals. It could also me a bad connection in a wire joint.
so, you track the circuit back to a point it is good. That, or the next box away from the panel is where your problem is.
Then you have the obscure problems, like I recently had, where a nail went through the NM. It only took 15 years for mine to surface as a problem.
Intermittent circuit, breaker not tripping lucabrasi Electrical 5 03-14-2010 07:03 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 01:47 PM
Circuit breaker keep retripping Gregg Electrical 4 02-18-2006 05:11 AM
