Circuit Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 03:33 PM   #1
Question
Circuit breakers
I just purchased a house & moved in April this year. I have 2 circuit breakers that are tripping. One to my dryer and one to my kitchen outlets & lights. The dryer breaker is now off until I get to that problem. The kitchen breaker is now blowing but only when I turn on a specific light switch. The light did have a dimmer on it and it would buzz and the light would flicker. I was told it was my high efficiency light bulbs and I need to remove the dimmer switch. Of course, I did not do that quickly. :\ Two days ago the circuit breaker to the light blew when I tried to turn on the light. I replaced the dimmer switch, but unfortunately that did not work and it continues to blow the circuit breaker (even without light bulbs in the light fixture). The switch has an outlet on it also, I can use that just fine...just don't turn on the light.
Questions: any ideas on the light switch problem would be helpful. Second - is it possible these two problems are connected? Two circuit breakers that are flipping off makes me a bit nervous.
owlwomyn is offline   Reply With Quote
Old 06-23-2011, 03:49 PM   #2
Too Short? Cut it Again!
Dryer should be on its own circuit so it has nothing to do with the light switch.
Are you saying you replaced the kitchen dimmer switch with another kitchen dimmer switch? What do you mean by high efficiency light bulbs. Are you trying to dim compact florescents or something? Not going to work.
Old 06-23-2011, 03:55 PM   #3
no I replaced dimmer switch with a regular switch and yes the lightbulbs were the compact fluorescent. Now..there are no bulbs in the light fixture and a regular flip switch...still blowing the circuit breaker.
Old 06-23-2011, 04:00 PM   #4
Could be a loose ground wire at the box. Breaker switch itself has bought the farm.
Outlets on 2 circuit breakers? travesty Electrical 8 04-05-2011 09:19 PM
2 breakers / 1 circuit dn100 Electrical 3 10-03-2010 08:01 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 12:34 PM
Circuit Breakers Unregistered Electrical 4 09-13-2004 08:49 AM
