Circuit Breaker Won't Reset - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2014, 11:10 PM   #1
circuit breaker won't reset
Hi, Guys. I was trying to locate a circuit by turning the breakers off and then back on until the circuit went dead. One particular breaker (20 amp) would not go back to the on position after having turned it off. I tried many times and waited probably an hour and tried again and the same thing. Is this most likely a bad breaker. The breaker has never been tripped before. I just turned it off and it wouldn't come back on. Thanks.
jeruss is offline   Reply With Quote
Old 06-12-2014, 11:14 PM   #2
Rewards Points: 13,468
Disconnect the black wire to that breaker and see if it resets.
What brand is it?
Old 06-13-2014, 03:49 AM   #3
Rewards Points: 324
I had same issue after replacing some light fixtures...turned out to be a bad breaker.
mgp roofing is offline   Reply With Quote
Old 06-13-2014, 05:52 AM   #4
Rewards Points: 774
Perform the test noted above but circuit breakers do go bad.
Know A Little is offline   Reply With Quote
Old 06-13-2014, 03:55 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
Agree. It definitely is not as common as most people think, but it does happen.
Old 06-14-2014, 07:00 AM   #6
Rewards Points: 1,452
Try pushing the breaker further toward the off side and then back to on. Some need this little extra step.
mikegp is offline   Reply With Quote
Old 06-14-2014, 01:35 PM   #7
Rewards Points: 774
Or smack it with a screw driver both options can work occasionally, But based on a residential throw away circuit breaker trash it and install new.
My belief is, if it won't turn on, who knows if it will trip when required to do so by a fault or overload.
Old 06-14-2014, 11:39 PM   #8
Hi, Guys. I just wanted to share my results. I was able to reset the breaker the next day, but the circuit was dead. I used a voltmeter to test the breaker, and it tested bad. I replaced it, and everything is back to normal. I appreciate all of your help. Thanks so much.
The Following User Says Thank You to jeruss For This Useful Post:
oh'mike (06-15-2014)
Circuit breaker not returning everything to power after switched back on sam112 Electrical 7 02-10-2013 12:48 AM
Circuit Breaker cover edscott Electrical 10 02-06-2013 10:22 AM
Circuit works on one breaker and not another kbhcdh Electrical 2 01-12-2013 05:45 PM
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 04:40 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
