Circuit Breaker- What Amperage Do I Need? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 07:39 AM   #1
Circuit breaker- what amperage do I need?
I have a NuHeat floor heating system which needs to be hooked up for this coming winter. The specs say the maximum load is 15A(1800W), an electrician bought a 20A breaker for the panel and had started the installation but never finished it. I need to know if this is the correct breaker or I need a 15A breaker.
Thanks in advance for any help,
Tom
TJTHEBOATER is offline   Reply With Quote
Old 09-15-2012, 07:44 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Tom
What size wire was run to the NuHeat?
Old 09-15-2012, 07:57 AM   #3
The wire coming from the installed NuHeat floor is 14 AWG, and the extension that runs to the electrical panel in the basement is 12 AWG. None of the wires are connected yet, FYI
Old 09-15-2012, 07:59 AM   #4
E2 Electrician
You have to use a 15 amp breaker if #14 AWG is part of that circuit.
Old 09-15-2012, 08:09 AM   #5
So the maximum load amperage doesn't have any affect?
Old 09-15-2012, 08:26 AM   #6
Master Electrician
Rewards Points: 3,870
Are the 14 gauge conductors a part of the branch circuit or are the 14 gauge wires you are talking about part of the floor heat factory assembly? If the wiring from the panel to the connectionn point of the heat assembly is 12 gauge then a 20 amp breaker is appropriate.
brric is offline   Reply With Quote
The Following 3 Users Say Thank You to brric For This Useful Post:
Julius793 (09-15-2012), mpoulton (09-16-2012), rjniles (09-15-2012)
Tags
breaker , circuit , circuit breaker , electical wiring , nuheat
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 09:45 PM
circuit breaker? blueandyellow Electrical 7 01-30-2011 10:27 PM
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 06:17 AM
main circuit breaker amperage kupalino Electrical 13 12-23-2009 08:32 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
