Circuit Breaker Trips Only When Switch Is Wired In - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 07:55 PM   #1
Question
circuit breaker trips only when switch is wired in
I'm trying to trace a very frustrating problem. Does it seem normal that a circuit breaker would only trip when a switch is wired in?
I'm wiring a shower light in a bathroom. There is just the line and load connected to a single pole switch. I got everything hooked up and turned on the breaker and it tripped. I tried connecting the line and load directly and the light stays on without tripping the breaker.
I've tried two different switches. The circuit isn't overloaded. There's not a water issue because the shower isn't hooked up yet.
There has to be short somewhere, but why wouldn't it trip anytime the circuit is completed?
Upstater is offline   Reply With Quote
Old 10-16-2011, 08:05 PM   #2
DIY staff
Rewards Points: 7,174
Take a picture of this---If the light works when the wires are nutted together but blows when a switch is installed then we simply don't have all the facts.
Upstater (10-16-2011)
Old 10-16-2011, 08:12 PM   #3
I can post pics tomorrow. I'm not living there currently.
Old 10-16-2011, 08:17 PM   #4
DIY staff
Good---I'm sure the answer will come with the picture----Mike---
gregzoll (10-16-2011)
Old 10-16-2011, 08:25 PM   #5
I=E/R
a7ecorsair's Avatar
Where is the power fed, to the switch box or to the fan box?
a7ecorsair is offline   Reply With Quote
Old 10-16-2011, 08:43 PM   #6
This is just a little 50watt in shower can light.
The fan is on a completely separate circuit.
The power comes in at the switch.
Old 10-16-2011, 08:43 PM   #7
Rewards Points: 6,652
Dead short, due to improper wiring the circuit.
Old 10-16-2011, 09:20 PM   #8
I=E/R
a7ecorsair's Avatar
It doesn't matter that it is a 50 watt light, the circuit is either 15 or 20 amps.
So, you have power coming into the switch box on a black and white wire. This black wire is connected to the switch. You have a cable going from the switch box to the light that also has a black and white wire. This black is connected to the other screw on the switch and the two white wires are wire nutted together.
Old 10-16-2011, 09:43 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Well, since several posters are asking us to use our crystal balls tonight , mine says this is a switch loop, and he has the fixture wired all black-to-black and white-to-white.
Dead short when the switch is turned on.
If not then something is simply wired wrong. Since we do not know what wires exist in what boxes it is all a guessing game.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (10-18-2011), gregzoll (10-16-2011)
Old 10-16-2011, 10:29 PM   #10
liscenced electrician
Rewards Points: 538
sounds like you have the switched wired wrong
jimmy21 is offline   Reply With Quote
Old 10-16-2011, 11:00 PM   #11
I=E/R
a7ecorsair's Avatar
Mine says the same thing....
The Following User Says Thank You to a7ecorsair For This Useful Post:
Old 10-17-2011, 03:35 AM   #12
Licensed electrician
Rewards Points: 1,296
am I the only one still using analog?
The Following 4 Users Say Thank You to Jim Port For This Useful Post:
frenchelectrican (10-18-2011), gregzoll (10-17-2011), RickyBobby (10-17-2011), Speedy Petey (10-17-2011)
Old 10-17-2011, 11:53 PM   #13
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
had a similar problem once. I rough wired some fixtures and ran power to the light fixture box first and then just wires to the switch and the guy doing the fixtures came in a day I was not around and did not know what he was doing and connected white to black and ground to ground in the box and then connected the switch and when the switch was turned on it would trip the breaker. because it shorted the wires out in the fixture box instead of turning the light on. Some people just don't understand even when you put black tape on the white to indicate the wires are just used for switching.
rrolleston is offline   Reply With Quote
Tags
circuit tripping , switch
Wiring a compressor scrapin Electrical 25 03-19-2012 12:35 AM
New Light switch trips breaker C2C Electrical 6 03-11-2011 04:26 PM
Heat pump circuit breaker pbms pinkertonpv HVAC 11 02-18-2009 10:47 AM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
