Circuit Breaker Tripping When I Turn On Kitchen Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 11:44 AM   #1
Circuit Breaker Tripping when I turn on kitchen light fixture
Hi, our house was built in 2009. We have a fluorescent light and a light fixture in the kitchen. In the last couple weeks when I have the fluorescent light on, then turn on the light fixture the circuit would occasionally trip immediately. Today I had both lights on successfully and about 10 minutes later the circuit tripped without touching the switch for either. Also when I turn the switch on for the light fixture I hear a electrical crackling sound kind of like when you have a switch half on and half off. I haven't had a problem prior to a couple weeks ago. I wonder if something is wrong with either the light fixture or the switch?
hiker23 is offline   Reply With Quote
Old 02-04-2012, 12:04 PM   #2
Rewards Points: 160
The circuit breaker is tripping due to a short. Start with a simple fix and replace the switch. Don't mess around too much though, this is the way fires start. Is there anything else on the circuit?
matt151617 is offline   Reply With Quote
The Following User Says Thank You to matt151617 For This Useful Post:
plummen (02-04-2012)
Old 02-04-2012, 02:30 PM   #3
Licensed electrician
Rewards Points: 1,764
Is there a reset button on the breaker. You may be tripping an AFCI breaker.
Light Breaker keeps tripping robbiecookie101 Electrical 3 05-14-2011 05:13 AM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 08:54 AM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 01:24 PM
Replaced Outlet, but now tripping the circuit breaker bman598 Electrical 9 05-21-2009 07:35 PM
Light Switch Keeps Tripping Breaker jackiesmom Electrical 23 05-24-2007 02:27 PM
