Circuit Breaker Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 04:37 PM   #1
I have a circuit that has been working fine for a number of years that just started tripping. It won't stay on for more than a couple a seconds. It hums and trips as soon as you reset it. I tried replacing the actual circuit breaker but it didn't help.
The load on the circuit hasn't changed. It's just a couple of lights and outlets at the top the stairs in the hall.
bad1129 is offline   Reply With Quote
Old 08-31-2011, 04:47 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
You have short!
If nothing has changed on the load, start looking for rodent damage.
jbfan is online now   Reply With Quote
Old 08-31-2011, 05:19 PM   #3
Electrician
Rewards Points: 802
What jbfan said and it could also be a bad breaker but i would go looking for a short first. If you have a multimeter you could check continuity between the black and ground and between black and white, if you have continuity you have a problem. If you do this make sure you don't do it with the power on.
darren is offline   Reply With Quote
Old 08-31-2011, 07:38 PM   #4
First remove all lamps and if any, disconnect ballasts as you will read continuity through them. Possibly a bad socket.
uconduit is offline   Reply With Quote
Old 08-31-2011, 08:45 PM   #5
Military Mom of 4
Snav's Avatar
I agree with the above.
When I started stripped the laundryroom for it's reno into a diningroom I found that a continually problematic plug had an exposed wire - so using that plug led to the occasional toss of the breaker.
I fix it - done - no problems.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 08-31-2011, 11:38 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,608
Yes you surely have a short circuit there somewhere.
Do you know all of the things on this circuit ?
Remove them one by one and try to re energise,
You will soon find the offending item,
If it is all removed, and you are 100% sure there is no more loads,
Then the fault lies in the wiring.
Just disturbing old wiring can cause problems.
Time to call an electricain.
dmxtothemax is offline   Reply With Quote
Old 09-10-2011, 04:54 PM   #7
Thumbs down
Circuit breaker tripping
I have a high hat ceiling light I hooked up to a switch and then to a 20 amp breaker with 14 gauge wire. The circuit trips right away and won't stay ON. Do I have to use a 15 AMP?
Pls advise
thanks
Iceheater
iceheater is offline   Reply With Quote
Old 09-10-2011, 05:03 PM   #8
The wire is brand new and I used a 20 amp breaker that was working for a small hard wired heater. It worked fine for the heater. I took off the heater wiring from the breaker but trips for the new light.
Old 09-10-2011, 05:57 PM   #9
Licensed electrician
Rewards Points: 1,876
You should have started a new thread.
Many heater as 240 volts. Did you check the voltage before you connected the light?
SD515 (09-10-2011)
Old 09-10-2011, 05:57 PM   #10
Pls advise
thanks
Iceheater
You cannot use the 14 gauge wire on a 20 amp circuit. You have created a fire hazard.
SD515 (09-10-2011)
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 04:40 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
