Circuit Breaker Tripped When I Touch The Junction Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 12:20 AM   #1
Circuit breaker tripped when I touch the junction box?
A newly 20Amp circuit breaker and wiring was installed two year ago. The new circuit has 3 lights and 2 outlets attached. One outlet is free and the other outlet is attached to a refrigerator. Circuit breaker was working fine for approx. 15 months until one day it tripped without warning. I tried to reset the CB but it would not work. So I left CB off for 2 days. Later I reattached the refrigerator and resetted the CB and it worked fine. The CB did not trip anymore. Last week, I was working around the house and accidentally touched the junction box which it was used for the CB. I felt a shock and the CB when off. I opened the Junction box. The wires were all nuted with no exposed wires touching the other wires. Also, the ground wire is not attached to the junction box. Not sure what when wrong. Can someone help. Thanks
Willie J is offline   Reply With Quote
Old 01-10-2011, 12:33 AM   #2
Rewards Points: 512
What junction box are you referring to; the receptacle outlet itself, the breaker panel, or an actual jbox with a cover over it?
Old 01-10-2011, 11:30 PM   #3
Thanks, Sirsparksalot
The Junction box is not the oulet itself or the breaker panel. The junction box I am referring to is the actual metal box with cover on it. The Jbox contains the wiring that is being splited and redirect the power/wires to the outlets and lights elsewhere in the house. There is no lights,outlets or switches attach to the Jbox directly. Thanks, I hope this helps.
Old 01-11-2011, 12:44 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Do you have actual bare conductor in your junction box ? if so they have to be bonded to the metal box.
Merci.
Marc
Old 01-11-2011, 06:26 AM   #5
Scared Electrician
Saturday Cowboy's Avatar
pictures please this sounds like a can of worms
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Circuit Breaker Question Bob Deb Electrical 15 11-29-2010 07:34 PM
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 01:04 AM
New circuit breaker owen22 Electrical 14 01-12-2010 07:08 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Circuit breaker keep retripping Gregg Electrical 4 02-18-2006 05:11 AM
