Circuit Breaker Testing Newbie Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 03:55 PM   #1
Circuit breaker testing newbie question
This might be obvious but I can't figure it out: I had an electrician over today to replace one of the circuit breakers since it's limiting current was to low for our washer/dryer. Instead of checking the numbers on the breaker itself, he stuck a multimeter in the electrical outlet where the dryer usually goes, looked at the numbers and said that this was a 20A breaker. I couldn't see his settings on the multimeter, but he said he measured the amperage. It was around 2.3 something. Now, here is where my confusion starts. How is plugging an ammeter directly into an outlet not tripping the breaker? Ammeters are supposed to have tiny internal resistance. I know the breaker's and the wire in the wall's resistances are negligible, so this leaves the ammeter with roughly 50 ohm shunt resistance (if the numbers I saw on the multimeter were indeed amps)? Was he indeed measuring amperage or was he yanking my chain? :-)
Please help remedy my confusion!
kyryk is offline   Reply With Quote
Old 08-04-2012, 04:10 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
WOW... what a scam....
Old 08-04-2012, 04:10 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,272
Someones chain is bring yanked. Either yours or ours.
Coastal South Carolina
Old 08-04-2012, 04:14 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Somebody got screwed.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-04-2012, 04:15 PM   #5
"So I Re-Wired It"
MisterZ's Avatar
i have had my chain yanked before.... believe me, it was an over-rated experience
just kidding, yah this sounds like a bunch of BS to me.
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-04-2012, 04:15 PM   #6
E2 Electrician
and it wasn't a light bulb....
The Following User Says Thank You to stickboy1375 For This Useful Post:
electures (08-04-2012)
Old 08-04-2012, 04:18 PM   #7
electures's Avatar
Lol....,
Old 08-04-2012, 04:21 PM   #8
E2 Electrician
Im going to skip over the scamming part, but I want to know what the name plate of the appliance was, the branch circuit wiring size, and the installed breaker size... BEFORE you called the so called scam artist.
Old 08-04-2012, 04:47 PM   #9
It's an LG dryer. It says on the back it requires a 30A breaker, just no one paid attention while installing it. The wire in the wall is 10 AWG, the old breaker was 20A. Despite all the scam artist comments, he wasn't bull****ting, the breaker was too small for the appliance. What surprised me is that he knew the limiting current by shortening the breaker, is this some sort of a trick of the trade? Now I feel that either his multimeter had a special function to do so, or there was a load on the testing leads.
Old 08-04-2012, 04:49 PM   #10
E2 Electrician
It's an LG dryer. It says on the back it requires a 30A breaker, just no one paid attention while installing it. Despite all the scam artist comments, he wasn't bull****ting, the breaker was too small for the appliance. What surprised me is that he knew the limiting current by shortening the breaker, is this some sort of a trick of the trade? Now I feel that either his multimeter had a special function to do so, or there was a load on the testing leads.
Well, yeah, any electrician knows a dryer needs a 30 amp branch circuit, but there is no way to install a meter and tell what size breaker is installed.... end of story. They probably only had a 20 at the time, and never replaced it, until you called, they spilt some crap of **** story on you as to not look like an ass.... it happens.
Old 08-04-2012, 04:54 PM   #11
Alright, thanks, I just wanted to make sure!
Old 08-04-2012, 04:57 PM   #12
E2 Electrician
Im not sure why they even tested the receptacle, I would have checked the breaker, saw that it was a 20, replaced the breaker if the branch circuit was sized properly, and been on my way.... the story he told you is just freaking odd as hell.
Old 08-04-2012, 07:06 PM   #13
Master Electrician
Rewards Points: 3,964
My guess is that something has been lost in the observation and/or translation.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Speedy Petey (08-04-2012)
Old 08-04-2012, 07:37 PM   #14
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm going to ask a silly question since it hasn't been addressed specifically...is this a gas dryer?
Old 08-04-2012, 08:44 PM   #15
It's not a gas dryer.
EDIT: That last sentence made no sense.
I don't see what could be lost in the observation: I saw him stick a handheld digital meter between two of the three terminals of the outlet, he said the breaker is too small for the dryer, I asked him what he was measuring to figure that out, and he said "amperage", my mind is blown, end of story. I wanted a more detail explanation, but he wasn't of the talkative type.
Breaker question emh918 Electrical 12 06-30-2012 09:26 AM
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 01:36 AM
New circuit breaker owen22 Electrical 14 01-12-2010 07:08 PM
Circuit Breaker, working in reverse dcwestcott Electrical 4 04-06-2009 03:03 PM
New homeowner here...circuit breaker question fenway71 Electrical 7 01-18-2006 08:39 PM
