Circuit Breaker - Sparks - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2013, 11:02 AM   #1
Hello,
I was changing a light in one my bedrooms and when I turned on the circuit breaker back on, sparks flew out (a little). The light wasn't working so I turned off the circuit breaker. Re-wired the lights and turned it on, sparks came on again but the light works fine. I then shut off the circuit breaker a and turned it back on a few times with no sparks. Everything is working fine in the house including that light and my question is, should I be worried there is a problem or is this a common thing? My circuit breaker is pretty old and I've been told by someone it's about 60 amps, well below standard for this day and age. But the house is very small (2/1, 1,000 sq ft). But should I be worried about anything?
Thanks!
armangdogg is offline   Reply With Quote
Old 09-17-2013, 11:17 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 384
Anytime you see sparks from an electrical device, there should be some worry.
You might need an electrician come look at it.
Old 09-17-2013, 11:20 AM   #3
Rewards Points: 756
if the breaker sparks it is probably loose and need inspection or replacement
carmusic is offline   Reply With Quote
Tags
60 amps , circuit breaker , sparks
Circuit breaker keeps immediately tripping after reset... Ler0y Jenkins Electrical 30 05-22-2013 01:17 PM
does a household circuit breaker have thermal memory? djmieczk Electrical 40 02-10-2013 06:59 PM
Circuit breaker not returning everything to power after switched back on sam112 Electrical 7 02-10-2013 12:48 AM
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 01:36 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
