Circuit Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2009, 10:05 PM   #1
Rewards Points: 31
Circuit breaker question
I'm adding a circuit breaker for receptacles in my basement and I'm wondering if using Square D Ground Fault 20-AMP circuit breaker (I think this has built in GFCI) with regular receptacles is the same as using a regular circuit breaker with GFCI receptacles down the line.
thanks.
kupalino is offline   Reply With Quote
Old 12-18-2009, 10:06 PM   #2
Yes you can use a GFCI breaker instead of a GFCI outlet
These are different from AFCI -arc fault
So make sure you get the right one
Old 12-18-2009, 10:14 PM   #3
Troubleshooting ground fault problems will be easier with indiv. GFCIs.
Old 12-18-2009, 10:26 PM   #4
That's true
So it depends upon what you are going to be plugging in & what you will be wiring
But...my pool cabana has had a GFCI breaker for all outlets & lights for 10+ years without a problem
I have since added more circuits....
Old 12-18-2009, 11:22 PM   #5
Idiot Emeritus
Rewards Points: 1,492
GFI receptacles are far less costly than breakers.
If you use the receptacles, and one trips, it's much easier to reset than going out to the panel.
Rob
micromind is offline   Reply With Quote
Old 12-19-2009, 12:00 AM   #6
Rewards Points: 1,016
Rob
X2 on both counts.
Old 12-19-2009, 12:35 AM   #7
Electrical Contractor
kbsparky's Avatar
Rob
Depends on where the receptacle vs the panel are located.
In the case of outside receptacles, venturing between snow covered bushes trying to reset an errant GFCI device is much more inconvenient than a trip to the utility room and opening the breaker box door.
-KB
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Circuit Breaker, working in reverse dcwestcott Electrical 4 04-06-2009 04:03 PM
Heat pump circuit breaker pbms pinkertonpv HVAC 11 02-18-2009 10:47 AM
Insulation around a electrical circuit breaker box terpsing Electrical 4 02-03-2009 04:08 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 01:52 PM
