Old 02-06-2013, 09:18 PM   #16
Ed Scott
Circuit breaker problem
There is one outlet that I know of that is causing the circuit breaker to pop. This has happened multiple times, to where I have had to buy 2 new breakers over the last 4-5 years. When I replace the breaker with the new one and reinstall the panel cover, the breaker trips. When I take the cover off and turn the breaker back on, it stays on. Once I try to reinstall the cover again, the breaker trips again. If I leave the cover off, the breaker stays working.
edscott is offline   Reply With Quote
Old 02-06-2013, 10:27 PM   #17
Couple questions for you, does the breaker trip if you just hold the panel cover on or after you install the screws to hold it?
Have you (with the power off) pulled the receptacle out that you know caused the trip, just to make sure there was nothing wrong with it?
Gac66610 is offline   Reply With Quote
Old 02-06-2013, 10:54 PM   #18
Pure Genius
Any chance you're hitting the wires for that circuit with your panel cover screws?
Dierte is offline   Reply With Quote
Old 02-07-2013, 09:50 AM   #19
Ed Scott
The cover can be held in place without the breaker tripping. Only when I screw the cover in place does the breaker trip. In the past I have had to gingerly place and screw the cover and it would be ok.
Old 02-07-2013, 09:52 AM   #20
Ed Scott
I have checked all of the wires that could be touched by the cover, but all wires look clear.
Old 02-07-2013, 06:50 PM   #21
Try putting one washer on each screw that holds the panel on,
these would act as spacers, thus the panel should now not
put as much pressure on the breakers.
Then see if it holds up.
This will tell you if the problem is caused by undue pressure
on the breakers or not !
If it makes no difference, then the problem lies elsewhere.
dmxtothemax is offline   Reply With Quote
Old 02-07-2013, 07:20 PM   #22
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Also are you using panel cover screws or some other type of sharp screws?
Sent from my iPhone using DIY Forum
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-07-2013, 07:33 PM   #23
Ed Scott
I will try that. I should mention that today when I was checking the box I noticed that the breaker I replaced was not seated properly. It was out of level. I think the problem may be that when I tried to put the panel cover back on, I was pushing on the breaker. We are having a big snow storm over the next few days so I dont want to play with it until later in the weekend.
Old 02-07-2013, 07:35 PM   #24
Ed Scott
Using the panel screws that I took out. Mentioned to another post that I will not be doing anything with the box until after the snow storm which is going to hit us this weekend.
Old 02-07-2013, 07:42 PM   #25
Ed Scott
I will not be working on the breaker box until after the weekend. Big snow storm heading our way. I will continue with a new thread after the weekend. I believe I may have found a fix, which I explained in a previous post. I will start a new thread if I need to after the weekend.
Thanks to everyone for the information and aid you have provided.
Circuit works on one breaker and not another kbhcdh Electrical 2 01-12-2013 06:45 PM
Circuit Breaker Bob Guercio Electrical 10 10-29-2011 04:19 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
