Circuit Breaker Keeps Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 10-02-2014, 07:29 PM   #1
Rewards Points: 2
Circuit Breaker keeps tripping
My refrigerator stopped working yesterday. Turned out that the breaker had tripped off. I have since replaced the outlet and the circuit breaker and the breaker continues to trip.
I have taken an extension cord and plugged the refrigerator into another outlet and that circuit doesn't trip.
If it's not the outlet or the circuit breaker and it's not the refrigerator because it works fine via another outlet, what is my next step?
Nan123 is offline   Reply With Quote
Old 10-02-2014, 09:08 PM   #2
joed's Avatar
Rewards Points: 13,762
The breaker trips when the fridge is running or on its own?
What else is on the circuit?
Is it a GFCI?
Is the circuit the fridge works on a GFCI?
Old 10-02-2014, 10:15 PM   #3
Rewards Points: 808
What else is on the circuit that trips? Refrigerators are not always on their own dedicated circuit. There could be other outlets in the kitchen, dining room, pantry that have an appliance or device that's causing the tripping.
IslandGuy is offline   Reply With Quote
Old 10-03-2014, 02:20 AM   #4
Rewards Points: 274
It is better that you can consult with the Electrical Expert in this regard.
alexjoe is offline   Reply With Quote
Old 10-03-2014, 08:25 PM   #5
220,221,whatever it takes
Rewards Points: 33
I agree with Alex. I went on a service call a few years ago with a similar complaint. The customer could not figure out why the dryer circuit kept tripping, even when not in use. it turned out that the breaker for that circuit was next to the main, and the main had gone bad. It was overheating, but not tripping. The heat from the main was causing the dryer breaker to trip (they trip from the heat of an overload). The insulation on the service conductors was melting and the wires and the main breaker were very hot to the touch. If I hadn't been called in the house would definitely have burned down.
Sooooo- call in a pro on this one.
Bernie Brewer is offline   Reply With Quote
Old 10-03-2014, 10:26 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,610
The next logical step is to find out what else is on that same power circuit ?
If it's not the fridge then it's something else.
Turn that breaker off,
then go around the house and see what is not working,
check everything,
as you need to know what the full load is for that breaker.
When you know what the total load is, make a list
Then add up the amperage for all those items ?
Compare that figure to the size of your breaker
or post the list on here ?
dmxtothemax is offline   Reply With Quote
Tripping Breaker cschuber Electrical 1 08-14-2014 02:51 AM
Lights on one circuit flicker now after tripping breaker shootmenow Electrical 8 04-13-2013 10:44 PM
11.5 amp blender tripping 20 amp circuit breaker MidgeTenant Electrical 17 01-22-2013 11:21 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
