Circuit Breaker Height - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2010, 01:32 PM   #1
Question
circuit breaker height
HI, i am installing a subfloor in my laundry room. My circuit breaker is currenty at 46in and after i install the floor it will be 26in from the floor. I have been reading the North Carolina electric standards and cant seem to find a reqired minimal height. Does anyone know if there is a required height?
ACE II is offline   Reply With Quote
Old 04-19-2010, 01:49 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome.
Mine is at 26" exactly, and passed inspection.
DM
Old 04-19-2010, 04:29 PM   #3
thanks
Thanks .......... it would cost some dough to have it raised, i dont want to if i dont have to.
Old 04-19-2010, 04:41 PM   #4
The only problem is if the total distance is too short
If removing the 20" in height means your panel is located in an area under 6' 6" in height that might be a problem
Old 04-19-2010, 05:01 PM   #5
the Musigician
Good point, Thanks Dave!
DM
Old 04-19-2010, 05:24 PM   #6
Rewards Points: 1,192
Dave, you always have the answer!
bobelectric is offline   Reply With Quote
Old 04-19-2010, 05:33 PM   #7
joed's Avatar
Rewards Points: 12,862
Code specifies a maximum height of the highest breaker. I don't believe it has anything to say about the lowest breaker. So technically it could be right at floor level and still be code.
Old 04-19-2010, 06:09 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
that is correct but Dave brought up a very important point. There is required headroom and clear space around a panel. Raising the floor may cause there it not be enough headroom.
Old 04-19-2010, 08:11 PM   #9
height
thanks for the quick response. I was debating on calling an electrican to the house to have it moved. Who knows if he would have told the truth or said that it should be moved just to make some money. ...... but i did measure the space on top and i have like 3.5 ft of room between the box and the ceiling. Currently its a 12 foot ceiling in there but when i put the aub floor in its going to take it down to about 8ft. so i guess im good now i just have to move the water heater. (no way around that) Thanks ALL..
Old 04-19-2010, 08:18 PM   #10
nap
You talking to me?
nap's Avatar
if you have 8 feet, it should be fine, until you have to buy shoes. Then it would get pretty expensive.
anyway, make sure the rest of the dimensions are adhered to as well.
30" clear space from side to side at least 3 feet in front of the panel.
Can't get the master circuit breaker properly seated davefoc Electrical 1 03-22-2010 06:17 AM
12 AWG circuit, Breaker 15A, 20A or either? SteveG Electrical 11 05-27-2009 12:05 PM
Dead circuit - Breaker not tripped Anne Electrical 2 08-09-2008 03:29 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 06:06 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
