Circuit Breaker Differences - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2009, 09:14 AM   #1
Rewards Points: 109
Circuit breaker differences
Need to add a few breakers to my panel for new circuits for bath remodel. I am likely going to hire this part out, but just out of curiosity, are all breakers the same? Meaning that home improvement stores carry multiple brands and even multiple models of the same rating breakers. I am sure when you shop for a light switch you can go by look and feel and color, but how does one shop for breakers?
BimmerRacer is offline   Reply With Quote
Old 09-01-2009, 09:21 AM   #2
In most cases the breaker you buy needs to be from the Mfg of the panel
Old 09-01-2009, 09:25 AM   #3
Rewards Points: 109
hrm...that covers the brand, but I think they still have multiple of lets say square d single pole 20A
Old 09-01-2009, 10:27 AM   #4
Different trip curves?
Old 09-01-2009, 10:47 AM   #5
There is the Square D reg 20a breaker
Then a 20a Square D Homeline breaker - less expensive model
Breaker must match the Mfg & in Square D's case the model line of panel
Old 09-01-2009, 11:33 AM   #6
Licensed electrician
Rewards Points: 1,742
If you read the label in the panel it will tell what types of breakers can be installed.
Like SD said the brands and types must match.
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
