Circuit Breaker Cover - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 07:40 PM   #1
Ed Scott
Rewards Points: 12
Question
Circuit Breaker cover
I replaced a circuit breaker with a grand new one today and after turning it on, everything worked properly. However, when I put the breaker wall plate back on, the breaker tripped. Took the wall plate off, and it worked again. This has happened many times with this same breaker, no matter which slot I use in the breaker box.
I left the box open. It is behind a shelf and not easily accessed so I don't see any problem with anyone tampering with it, but wonder if it is safe to keep it open.
Anyone have any idea why the breaker would trip when the face plate is on, yet work fine when the plate is off? Especially when considering that I have moved the breaker to another location in the box. Very confused.
edscott is offline   Reply With Quote
Old 02-04-2013, 08:57 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by edscott View Post
I replaced a circuit breaker with a grand new one today...
did you have the problem BEFORE you installed the new breaker?
Old 02-04-2013, 09:34 PM   #3
Trucon01's Avatar
Rewards Points: 510
Is the box and wall plate metal or plastic?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 02-04-2013, 09:45 PM   #4
Rewards Points: 160
Typically, this is because the cover plate for some reason hits the breaker handle and trips it. Check to make sure you've mounted the plate so it doesn't touch the breaker handle. There's often enough slop in the cover plate holes so that you can move the plate around quite a bit and still get the screws in.
philS is offline   Reply With Quote
Old 02-04-2013, 10:01 PM   #5
Missouri Bound's Avatar
What's a "breaker wall plate"? Are you talking about the outlet box? Is this a GFCI breaker?
Do you want it your way or the right way?
Old 02-05-2013, 07:11 AM   #6
Rewards Points: 160
I think it's pretty obvious he's talking about about a load panel and the metal cover. I also think it's likely he isn't with us anymore. Cheers.
Old 02-05-2013, 07:27 AM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would say that one of the screws is hitting a hot wire and tripping the breaker and the breaker panel can't be hidden behind a shelf.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-05-2013, 09:32 AM   #8
Ed Scott
Rewards Points: 12
Yes, I am talking about the metal cover. This problem has happened before, over the last 2 years or so the breaker has tripped numerous times. Eventually the breaker would not work at all. I have checked the wires that are connected to the breaker and they don't seem to be touching any part of the cover. But I will recheck and try again,. Thanks. I will post later.
Old 02-05-2013, 09:51 AM   #9
Ed Scott
Rewards Points: 12
Checked the cover screws
Okay, I just checked the cover screws and it seems like one of the screws might be touching a ground wire going across the bottom of the box. I will adjust the ground wires to place them further back in the box. Won't get to this until later in the day. Thanks again for all the help.
Old 02-05-2013, 09:52 AM   #10
rrolleston's Avatar
Also breakers that trip repeatedly wear out easily. Could be a short somewhere that you are not seeing.
Old 02-06-2013, 10:22 AM   #11
Ed Scott
Rewards Points: 12
I have one followup question which I will access later in the day. One of the suggestions was that it was possible that one of the cover plate screws was hitting a wire. I checked inside the box and none of the wires connecting to the breaker are near the screws, but the ground wires in the bottom of the box may have been touched by one of the screws. Would the screw touching the ground wire cause the breaker to trip?
Circuit works on one breaker and not another kbhcdh Electrical 2 01-12-2013 05:45 PM
Can a Square D 4 pole circuit breaker be used as a 2 pole circuit breaker. TifcoJim Electrical 3 08-23-2011 11:59 PM
New circuit breaker owen22 Electrical 14 01-12-2010 07:08 PM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 09:14 PM
Heat pump circuit breaker pbms pinkertonpv HVAC 11 02-18-2009 09:47 AM
