Circuit Breaker For An A/C Unit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 07:43 PM   #1
Circuit breaker for an A/C unit
My A/C unit shows a minimum AMP load to be 18. The breaker that I have it on is a 15 AMP. It never trips but when the A/C turns on, the lights in my house dim for a few seconds. How do I fix this?
hitchh is offline   Reply With Quote
Old 07-24-2012, 07:47 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Call your power company so they can just tell you nothing is wrong. seriously, people claim hard start kits work, that is probably your best option.
Also, you should probably change the breaker for your AC unit just so that one day it doesn't trip. Look at the nameplate for the MAXIMUM BREAKER SIZE and go with it.
Old 07-24-2012, 07:55 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
This is VERY common, and most likely there is no "fix" because most likely nothing is wrong.
Speedy Petey is online now   Reply With Quote
Old 07-24-2012, 07:56 PM   #4
E2 Electrician
Mine does to by the way. I just accept it.
Old 07-24-2012, 08:04 PM   #5
Same here.
Old 07-24-2012, 08:31 PM   #6
E2 Electrician
Originally Posted by Speedy Petey View Post
Same here.
I've read that women are more susceptible to seeing this occurrence than men, obviously you and I don't count because we're electricians, but it's always intriqued me if this was actually true or not.
Old 07-24-2012, 08:59 PM   #7
Rewards Points: 6,652
Mine does for maybe half a second, depending on the current load on my system at that time. It is just the nature of the beast, when a large load comes online. Unless you have a isolation transformer on stuff like hvac, you are always going to see a slight dimming when the system kicks on.
If you are wanting to know more what your electrical system is doing in your home, suggest investing in something like a Ted5000, that you can monitor what is going on.
When I came home at six, my cur. volt was 223, due to the other eight houses on the transformer I am on, are also running their ac, watching tv, prob. doing laundry, running the dishwasher, etc. right now. Summer is killer when it comes to putting large loads online on a system that for some areas can barely maintain proper voltages for the demand, along with Kw use.
Old 07-25-2012, 06:57 AM   #8
dmxtothemax's Avatar
Rewards Points: 5,102
You most likely cannot fix this !
As it is perfectly normal !
Usually it is a POCO short coming,
But not normally considered a fault.
As for the breaker size,
You really should get a 20 A breaker !
When you can.
By the way a HUGE capacitor across your mains feed would fix the problem !
But I doubt you could afford such a beast !
It would be huge and expensive !
But technically possable.
dmxtothemax is offline   Reply With Quote
Old 07-25-2012, 11:52 AM   #9
Rewards Points: 1,192
They dim because xfmr sizing.
bobelectric is offline   Reply With Quote
Old 07-25-2012, 06:42 PM   #10
Julius793's Avatar
well if you were to upgrade to a 400a service it may just solve the problem.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 07-25-2012, 06:52 PM   #11
How do you figure?
Old 07-25-2012, 06:53 PM   #12
E2 Electrician
How do you figure?
I was assuming it was sarcasm....
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (07-25-2012)
Old 07-25-2012, 06:58 PM   #13
If the problem really is a lack of power in POCO's system,
The bigger wires will only provide a marginal improvement.
A bigger tranny would help thou !
Can a Square D 4 pole circuit breaker be used as a 2 pole circuit breaker. TifcoJim Electrical 3 08-24-2011 12:59 AM
Circuit Breaker Question Bob Deb Electrical 15 11-29-2010 08:34 PM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
