Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 03:15 PM   #1
JJL
Circuit breaker
Breaker switch to my bathroom will not reset. After about 4th attempt to reset, it made a buzzing sound (electricity) and saw a quick spark. I am assuming the switch needs to be replaced, but I can not find a main breaker switch on the panel. My question is, Is it safe to change the switch without turning off the main breaker switch or should I call an electrician? I tried to search for an answer here before I posted.
JJL is offline   Reply With Quote
Old 12-28-2009, 03:24 PM   #2
Licensed electrician
Rewards Points: 1,012
You need to determine why the breaker is tripping. Unplug everything on that circuit and see if the breaker resets. Has any work been done on this circuit? Has anyone hung a picture on the wall that may have damaged the cable?
Old 12-28-2009, 03:28 PM   #3
the Musigician
DangerMouse's Avatar
Originally Posted by JJL View Post
Is it safe to change the switch without turning off the main breaker switch?
Hi and welcome to the forum.
No, it is certainly NOT safe! Is there a box outside on a pole perhaps?
shut the power OFF before doing any work on the panel.
DM
Old 12-28-2009, 03:44 PM   #4
Rewards Points: 1,016
There may be another panel or disconnect switch which contains the main disconnect - separate from the breaker panel you are looking at.
Old 12-28-2009, 03:48 PM   #5
JJL
Nothing is plugged in. There are only a light and a fan which comes on together. It in an office building setting, so I may have to get an access to the electrical room. I think I should just call an electrician.
Old 12-28-2009, 04:58 PM   #6
joed's Avatar
Rewards Points: 11,536
Office buildings are not a place for DIY. You must call an electrician for this.
Sounds like there is a short on the circuit somewhere.
Old 12-28-2009, 06:15 PM   #7
The landlord is responsible for this, an electrician needs to be called in to work on the issue in an office building
wiring a arc fault circuit breaker mikebjohnson Electrical 20 05-01-2011 12:21 PM
Circuit breaker question kupalino Electrical 6 12-19-2009 12:35 AM
loose circuit breaker justorr Electrical 5 11-28-2008 04:14 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
