Circuit Break Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2013, 07:05 AM   #1
Circuit break wiring question
I have a circuit breaker in my electrical panel that is getting overloaded and tripping frequently. This 15A circuit breaker is feeding a total of 22 outlets, 5 ceiling light fixtures(two light bulbs), and a ceiling fan with 4 light bulbs(3 rooms, a hallway and stairwell). I still have 2 open slots in the electrical panel but when I look at the circuit breaker in the electrical panel I just have 3 wire, the ground, neutral and hot how can I find where all of the sub circuits are getting tied in?
avengerki is offline   Reply With Quote
Old 11-01-2013, 07:11 AM   #2
Rewards Points: 13,694
Please go back and add your location to your profile. Location can be a big factor when it comes to code related questions. Just go to quick links to edit.
How old is this house?
What type wiring do you have?
Access under the floors or above the ceiling?
Old 11-01-2013, 07:33 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
It will take some busy work to deduce the path of the circuit. Could go to a junction box and split off into different paths from there. (good) Or it could be a string of daisy chained devices from start to finish. (not so good) You will need to figure this out before you can come up with a good plan of attack. It is busy work because you have to open up every outlet, switch and light fixture to see how many sets of conductors are present and do a lot of disconnect reconnect to determine where it is coming from and where it is going to.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-01-2013, 07:34 AM   #4
How old is this house? Built in 2002
What type wiring do you have? 3 conductor romex I believe can't remember wire size right now
Access under the floors or above the ceiling? Technically I have access from above the ceiling, and have been thinking of making a hatch to have access below also which would allow above access for the first floor.
Old 11-01-2013, 07:37 AM   #5
I had a feeling that was what would be said. Would the junction box probable location be in the ceiling, wall, or below flooring if there is one?
Old 11-01-2013, 07:41 AM   #6
PoleCat's Avatar
15A breaker would make me believe that the circuit or part of it is run in 14ga wire. Do the wires at your service panel all go up into the attic?
Old 11-01-2013, 07:42 AM   #7
PoleCat's Avatar
Junction boxes must be in an accessible place. Attic or crawl space.
The Following User Says Thank You to PoleCat For This Useful Post:
avengerki (11-01-2013)
Old 11-01-2013, 07:43 AM   #8
PoleCat's Avatar
If you can find a JB in the attic that is fed by that breaker then your day just got a whole lot better.
Old 11-01-2013, 07:47 AM   #9
They all exit at the top of the service panel, whether they all up into the attic from there I hope so but this builder was found to of taken alot of shortcuts and weird decisions.
The problem with the attic is I've got that blown cellulose type insulation like a foot deep.
Old 11-01-2013, 07:58 AM   #10
PoleCat's Avatar
I hate crawling around in that stuff too. Buy a decent mask. If you have a hip roof and your panel is in the corner of the house you are in for a rough time when you pull new wires. It is still easier though to make the effort to locate that junction box first if there is one. Get a voltage tic that lights up when you hold it next to a live circuit. They are great for this kind of task. You just turn off the breaker then go up and find the cable that doesn't light it up. This can be either your feed or a switch loop. Follow it to the JB or where it goes back down. It could also go straight to a ceiling fixture too in which case that is ground zero.
Old 11-01-2013, 08:04 AM   #11
PoleCat's Avatar
If it goes down into a wall then to a switch it may just be switch loop. You would need to go down and open up that switch to see if has just one set of wires in it. If so it is just a switch loop. Otherwise it is feeding other devices and the you just keep pecking away until you have a drawing of of the entire circuit.
Old 11-01-2013, 08:15 AM   #12
This is where a walkey talky and a non contact tester to narrow things down comes in handy and two people.
Gets old going up and down all day.
Old 11-01-2013, 08:19 AM   #13
Yep, last time I went up there to look for something I wound up yelling to my step-son and he didn't always understand what I said so he went up and down. It was great division of labor though.
Old 11-01-2013, 09:14 AM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I doubt there us a JB in the attic. More likely the circuit just goes from device box to device box.
Coastal South Carolina
The Following 3 Users Say Thank You to rjniles For This Useful Post:
k_buz (11-02-2013), Philly Master (11-13-2013), Speedy Petey (11-03-2013)
Old 11-01-2013, 09:23 AM   #15
Licensed electrician
Rewards Points: 1,608
X2. Junction boxes really aren't used in the newer wiring styles.
Instead of trying to split the circuit, try to install a new circuit where needed. It sounds like you have too much load plugged in.
k_buz (11-02-2013)
Question about wiring A/C to circuit panel? word2yamutha Electrical 18 09-05-2013 04:12 PM
Replacing Cooktop, Circuit Amperage Question diverdave Electrical 23 07-20-2013 09:54 AM
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 01:36 AM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 08:15 PM
Circuit Size Question techinstructor Electrical 12 06-28-2009 08:24 AM
