Circuit Board Repair For Pellet Stove - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2010, 12:30 PM   #1
circuit board repair for pellet stove
I have a Whitfield wp2 advantage pellet stove that has circuit board problems. since the stove was built in 1988, new circuit boards are not available. Any suggestions about repair?
mudmusic8 is offline   Reply With Quote
Old 06-03-2010, 02:07 PM   #2
Just curious, but how do you know the circuit board is the problem. Just asking because fixing it will be the hardest of the things that could be wrong
Troglodyte is offline   Reply With Quote
Old 06-03-2010, 02:22 PM   #3
If it's a damaged board (cracked or marred) you could look at this video.
http://www.ehow.com/video_2369818_re...it-boards.html
Old 06-03-2010, 04:02 PM   #4
Post closeup photos with component numbers legible; getting a schematic for the board is probably too much to hope for. If it's simple enough or uses relay logic you maybe can build a new one.
Also post a stove schematic, owner's manual, parts list and spec. sheet, if you can.
Old 06-03-2010, 10:08 PM   #5
Union Electrician
goose134's Avatar
This says the stove was made in 1990 so I'm not sure if it's the right one....
http://www.stove-parts-unlimited.com...p/12055902.htm
Pretty steep replacement.
goose134 is offline   Reply With Quote
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
dryer & stove sharing circuit? teamSpatula Electrical 9 09-16-2008 02:59 PM
cord to my heating pad got ripped out from its circuit board..any help? flashme18 Electrical 8 07-09-2008 10:28 PM
Inducer fan assembly or inducer control circuit board failing realblonde94526 HVAC 3 05-12-2008 07:28 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
