Circuit Blows When I Turn Off Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 11:36 PM   #16
Rewards Points: 206
I can reach my hand up in the ceiling and tell which piece of romex is going to the switch and which is going elsewhere. Will that tell me which wires go where?
joeg679 is offline   Reply With Quote
Old 04-18-2011, 12:14 AM   #17
joed's Avatar
Rewards Points: 11,628
Tell us about the wires on the switch as well. Which cable has the red? The one to the switch or the one to the vanity.
If you know tell what connected to what in the fixture before.
Old 04-18-2011, 12:31 AM   #18
Rewards Points: 206
There is a double box with the vanity and fan switch in it, but they work independently. Then above, there is a single bod that had the thermostat control for the old heater and that only has black and white romex. The only red wire that I see is from the heat lamp.
Old 04-18-2011, 09:45 AM   #19
joed's Avatar
I repeat.
Old 04-18-2011, 09:46 AM   #20
Rewards Points: 1,418
If you can tell then why are you asking. However I am led to believe that the first sentence is false and that you must do voltage measurements.
One more test. After doing the voltage measurements, turn off the breaker. NOw set the meter to ohms or continuity and test the two wires of the cable that showed no voltage. It should show no continuity when the switch is off and show continuity (near zero ohms) when the switch is on. Twist the thermostat knob to see if anything changes. Never do ohms or continuity or resistance checks on a live circuit.
When you said that the heat lamp has a red wire, does it also have a white wire and a black wire? What does its instructions say about the three wires? You would need to connect up the white wire from the heat lamp to neutral and connect either other to the hot feed in turn and see what happens (does the heat lamp have low and high settings that you could choose only one of given only one pair of wires down to the switch).
Old 04-18-2011, 10:32 AM   #21
Rewards Points: 206
The lamp has a white, red and black wire. The instructions say to connect the white to the either and the red and black to the black. I have 2 blacks and 2 whites coming out of the ceiling. I put the 2 blacks together and connected them to the black and red from the lamp and did the same with the white.
Old 04-18-2011, 12:51 PM   #22
joed's Avatar
Tell us about the wire connections in the switch box.
In the ceiling which cable has the red wire. The one going to the switch ot the one to the vanity.
Old 04-18-2011, 01:08 PM   #23
Rewards Points: 206
I can't see the actual wires from the vanity or the connections. There is a very small hole to stick my head up but I can feel the wires going in different directions, at a point. One goes towards the vanity light an ms the other goes towards the switch. In the switch, there is only a black and white.
Old 04-18-2011, 06:46 PM   #24
joed's Avatar
In the ceiling.
The appears to have been for the heater. Cap it. You don't need it. That appears to have been power to the old heater.
Take the white from the switch cable and connect it to the other blacks in the box.
Take the white from the fixture and connect to the remaining whites in the box.
Take the light fixture black and connect to the black from the switch.
Old 04-18-2011, 10:22 PM   #25
Rewards Points: 206
In the ceiling.
What are u saying I should cap? There is a red and black from the lamp, should both be connected to the black from the switch? Thanks
Old 04-18-2011, 10:24 PM   #26
Rewards Points: 206
[QUOTE=joed;632026]In the ceiling.
Old 04-18-2011, 10:41 PM   #27
joed's Avatar
Tell me more about this lamp fixture. I thought it was just a lamp with two wires. If it has three wires then it has a lamp and ????
The red wire in the ceiling from your description goes to the thermostat on the wall.
Old 04-18-2011, 10:51 PM   #28
Rewards Points: 206
I don't even see a red wire in the wall, but I guess there is one. The lamp is 2, 250 w heat lamps and s small propeller fan that blows the heat down.
Old 04-19-2011, 08:57 AM   #29
joed's Avatar
You got me totally confused as to what you have. I think it's time to call in an electrician for this.
The Following User Says Thank You to joed For This Useful Post:
joeg679 (04-20-2011)
Old 04-19-2011, 12:39 PM   #30
Consider just the black and white wires. You need to connect them in three groups of two instead of two groups of three.
With three groups of two -- Power comes in on one wire (#1, hot), goes to switch (#2), comes back from switch (#3) goes to heater (#4), comes out of heater (#5, neutral), returns to panel (#6, neutral). Note that #1 has to be the hot wire (hence the needed voltage measurements) and is black. #3 and #4 may not be white. #5 must be white. And #6 is the white wire in the cable with #1.
If the above doesn't work then use the red wire in the heater as #4. (Or connect the red and black heater wires together and use as #4)
With two groups of three (doesn't work) -- Power comes in on one wire (#1), goes to switch #2), comes back from switch (#3), returns to panel (#6) and trips the breaker because this is a short circuit. Power also has the choice of coming in on #1, going to the heater (on #4), coming out of the heater (#5) and returning to the panel (#6) and will do this when the switch is flipped off preventing the come back on #3.
The Following User Says Thank You to AllanJ For This Useful Post:
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 01:31 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Add a separate switch to a 3way circuit skyhigh82 Electrical 3 03-23-2009 12:21 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 01:43 AM
