Circuit Alert Goes Wild - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2005, 11:27 AM   #1
Circuit alert goes wild
Can anyone explain why my Fluke circuit alert goes crazy once in a while and shows everything as hot, (fixture, hot, neutral, ground)? The master electricians usually mumble "magnetic field" to me but I'm looking for a little more detail. Even bad guesses are appreciated. Thank you in advance. HS
K2eoj is offline   Reply With Quote
Old 10-16-2005, 09:11 PM   #2
Could be the detector is picking up on voltages caused by induction on the non-hot conductors, hard to tell. Put a decent multimeter on the others to test, my fluke would often pick up on stray voltages, but when metered would show only a few volts.
The hot conductor is close in proximity to the others, when there is an AC voltage on it, the magnetic flux caused by that voltage induces voltage on the other conductors. Good enough?
Sportbilly is offline   Reply With Quote
Old 10-17-2005, 09:57 AM   #3
Red face
Sports, thanks. Your reply will get me in the right direction and that direction should lead me back to a classroom.:o HS
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Finding "Champion" brand circuit breakers? Jemo Electrical 5 03-11-2007 01:28 PM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 09:26 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
