Circline Bulb And Ballast - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2010, 11:03 AM   #1
Circline bulb and ballast
I'm trying to set up a 16" florescent circline to use as a continuous light for stills. I ordered the ballast and the bulb but I'm confused on how to set it up. The bulb has four prongs and the ballast has a few wires. Anyone have experience with this outside of a wall or fixture setup?
The bulb
FC16T9/Utility/40W/16
www.superiorlighting.com/v/vspfiles/photos/20037-SYL-1.jpg
the Ballast
images.grainger.com/B310_32/images/products/450x450/2W769...
Fc12t9 Lamp
Fluorescent Electromagnetic Ballast, Lamp FC12T9, Number of Lamps 1, Input Voltage 120, Input Power 40 Watts, Minimum Starting Temperature 50 Degrees Fahrenheit
PHILIPS ADVANCE
RL-140-TP
anton2148 is offline   Reply With Quote
Old 07-06-2010, 11:22 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
here is a pdf that has the connection diagram:
https://www.elliottelectric.com/Inve...DV/RL140TP.pdf
you will want to get the terminal for that type of light to attach the wires to. You light be able to get the clips that are in the fixture that are used to mount the light as well.
Old 07-06-2010, 11:47 AM   #3
Thanks, but I'm a real novice. I think I need a picture or a video of how this works. Right now i'm up ****'s creek.
Old 07-06-2010, 01:02 PM   #4
nap
You talking to me?
nap's Avatar
Um, there is a picture on that page.
Old 07-06-2010, 02:26 PM   #5
I only see a diagram. I don't know what tools or extra parts I need or exactly how to connect the ballast to the bulb. The ends of the wire on the bulb are naked. And the bulb has four mail prongs. I think I need a socket for both ends of the ballast.
Old 07-06-2010, 02:57 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Not really.,
You will need total of 6 wirenuts either yellow or orange wirenuts { many big box store and hardware store will stock this anyway }
you follow the diagram very carefull it can not be miswired at all and you need a cirulculer flourscent socket some big store may have it and follow the wires leads and colours { note they are keyed so they will fit into the bulb one way but not the other.}
The tool you will need is wirestripper to strip the insulating materal off from the conductors you only need to strip about half inch that it noting more than that.
They are pretty simple to hook up red #1 to red #1 and #2 red to #2 red then bleu to bleu and white to white that it.
the supply side the black to black and white to white plus the white from the tombstone connector that will be wirenutted together.
Make sure you have good ground connection as well otherwise the circline bulb may have hard time to kick on.
C'est simple.
Merci,Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
anton2148 (07-06-2010)
Old 07-06-2010, 03:16 PM   #7
Originally Posted by frenchelectrican View Post
Not really.,
C'est simple.
Merci,Marc
Thanks. Know any places online to find the right socket? I live on Miami Beach, and am currently carless. Not the best place to look for hardware. So the socket will connect to the bulb and the wall?
Ultraviolet bulb blown morr6241 HVAC 12 06-06-2009 10:00 PM
Blown Ultraviolet bulb morr6241 Electrical 1 06-06-2009 06:42 PM
Commercial Ballast for Residential ???? lanyard_loop Electrical 4 11-11-2008 01:52 PM
Metal halide lamp Richo Electrical 13 01-20-2008 02:37 PM
please help w/ selection of bad ballast Mack V Electrical 8 10-17-2006 09:54 AM
