Old 11-23-2012, 02:52 PM   #1
Christmas Lights - Amps
Christmas Lights Run 250 feet from house to a tree near road. There is an outlet. Extension cord. Split to many extension cords then split to many lights. Also split after first EC to a few extension cords going to two wreathes. The lights are LEDs and it says 90 stands take less than 2 amps. We have had amp issues before but want to know if the distance of extension cord itself takes amps? Or does it just supply the one/two amps?
austinbblock is offline   Reply With Quote
Old 11-23-2012, 05:15 PM   #2
There will be a small loss of Volts not amps,
( Lower volts make amps rise )
But if you use a good size cord (thick as poss')
and if the load is low, like only 2 amps
then the loss will be very small
not enough to worry too much about.
dmxtothemax is offline   Reply With Quote
Old 11-24-2012, 12:04 PM   #3
Semi-Pro Electro-Geek
Only for a motor load, because motors are weird. Resistive loads like lights, heaters, and almost everything else follow Ohm's law: I=V/R. Lower voltage results in lower current.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Speedy Petey (11-24-2012)
Old 11-24-2012, 02:02 PM   #4
Just to give you an idea of how minimal the voltage loss is with LEDs.
1000 ft of #16 wire (typical light duty extension cord) has about 2.5 ohms of resistance. So 2 amps of current would result in 2 * 2.5 = 5 volts lost in the resistance of the extension cord, leaving a nominal 120 - 5 = 115 Volts available to the LEDs.
Dave632 is offline   Reply With Quote
Old 11-25-2012, 01:57 AM   #5
I think the general concensis is -
Running a load of 2 amps over 250 ft
will not be a problem.
The only time it becomes a problem is with bigger loads,
So if your getting up around 10 amps or so,
A thicker power lead would be required.
A good rule of thumb is for long runs of cable
you should double the current rating,
So instead of using a cord rated for 10 amps
use a cord rated at 20 amps.
And to be technially correct leads dont eat up amps,
instead they eat up volts.
Recessed Lighting and outlets under roof eves justjeffDIY Electrical 4 11-09-2011 02:13 PM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
Christmas Tree Lights timchi29 Electrical 2 11-23-2009 01:12 PM
Generator as sole power source NGuy Electrical 29 12-20-2008 01:29 AM
help with christmas lights!!!!! reds_21 Electrical 11 11-28-2007 11:02 AM
