Christmas Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 01:05 AM   #1
Rewards Points: 12
Christmas Lights
Hello. I joined this forum just to get help with a question I've been trying to get answered for over a month. Any help would be greatly appreciated.
I have a tree lined driveway at my house, and I want to put Christmas lights in each tree. (I'm getting married this summer, the wedding is in our backyard, and white lights in each tree lining the driveway would look cool)
Here is the problem: it's a long driveway with many trees, and the only power outlet is on the outside of the shop at the end of the driveway. (I drew a little map for a picture of what I'm working with)
How can I safely get power to each of these trees to make this work?
We've already bought 22 boxes of lights. There are 2 strings of 200 lights in each box. So that is 44 strings of 200 lights. There are 25 trees total, so most trees will have 2 strings, but some of the smaller trees will only have one. Each string of lights has a 3 amp fuse, with 2.5v bulbs. The breaker that the outside outlet is on is 20 amps. Each string consumes 48 watts, which is 0.4 amps. I have 44 strings, so 44*.4=17.6 amps. So I'm thinking that is about perfect on the 20 amp breaker. The only thing I am unsure of though is the distance. Does the fact that I need to run around 400 feet of wire change anything?
Can I just run burial cable in trenchs along each side of my drive way, put outdoor outlets every other tree or so, and make this safely work?
Thank you in advance for any help.
airon26 is offline   Reply With Quote
Old 05-30-2011, 01:10 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
this sound like a good way to start.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-30-2011, 09:57 AM   #3
Rewards Points: 12
I just wasn't sure if there would be too much voltage drop for this to work.
Old 05-30-2011, 10:08 AM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I would use 12 or even 10 awg wire with upstream GFCI. Conduit is probably a good idea, with a plug sticking out every now and then.
Old 05-30-2011, 02:48 PM   #5
Scared Electrician
lights are more tolerable than most electrical loads of voltage drop. up sizing your wire one size will help
Old 05-30-2011, 03:17 PM   #6
Bunited2
Bunited2's Avatar
Send a message via Yahoo to Bunited2 Send a message via Skype™ to Bunited2
I don't think they are 2.5v bulbs, but 2.5w bulbs.
I can understand wanting to have the Christmas lights in the trees for
that 'special occasion', but Christmas lights are Christmas lights.
I would not spend the time and expense doing a direct burial for Christmas lights,
but do 2 generators behind the trees with extension cords to power the lights.
If I was going to actually go through the expense and trouble of doing
direct burial, I would do spot lights in the ground facing up at the trees
maybe lighting up 3-5 trees at a time. Face the spot lights at the trees
across the road from each of the lights.
If you really want to be special, if you run the cable also run a cable to the
end of the trees and install a motion detector at the first tree, that whenever
someone comes up the road the tree lined road would light up.
To be really, really special, have motion detectors every couple of trees that
would turn on the light ahead as the car drives up, instead of all the lights at once.
Would make a 'heck' of a preventative security system also.
Bunited2
Bunited2 is offline   Reply With Quote
Old 05-30-2011, 08:53 PM   #7
Wire Chewer
Rewards Points: 132
THAT would be awesome. It should only work with Coke transports though.
I need to start thinking up of Christmas lighting ideas myself, now is the time to do any installations... not when it's 40 below.
Old 05-30-2011, 10:58 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,492
If you run two cables,
One on each side of the driveway,
That would solve the problem of voltage drop,
As each line only has half the load.
But double check that the power consumption is correct.
dmxtothemax is offline   Reply With Quote
Problem with Christmas lights burning out asugrads Electrical 21 12-20-2011 02:28 PM
Let's See Some Christmas Lights Nathan Project Showcase 4 01-07-2009 12:59 PM
Christmas lights under vinyl siding? DangerMouse Electrical 14 10-03-2008 05:58 PM
help with christmas lights!!!!! reds_21 Electrical 11 11-28-2007 10:02 AM
