#1 |
Christmas light problem
I have two lighted deer that I use in my outdoor light display. The deer are a wire frame with strings of white lights clipped to it. I'm having problems getting the lights to work correctly this year. Some of the strands of light will only have half the lights work. The first half of the strand starting from the plug won't work, then the second half will. Each deer has several strands on it that are doing this. Also, one of the deer has antlers where none of the lights on that strand work. I've tried replacing the fuses in the plugs and I've tried checking to make sure the bulbs are seated properly. Any suggestions on how I might get these to work?
Thanks. |
#2 |
You have to find the loose or missing bulbs. If part of a string works, the problem isn't the fuse.
| Display Modes | |
| Icicle at base of exterior light -- insulation problem? | curls00 | General Discussion | 1 | 11-20-2007 11:14 PM |
| Trane 80xl, 3 flashes error light - draft pressure problem, help? | Xsta | HVAC | 1 | 10-14-2007 09:20 PM |
| Trouble installing ceiling light fixtures: same problem x3 | sweetroad9 | Electrical | 5 | 04-13-2007 02:46 PM |
| Laundry Room Light switch Problem | Crash44 | Electrical | 7 | 02-15-2007 04:01 PM |
| Hot Light Outlets | Materials Guru | Electrical | 5 | 07-31-2006 08:11 PM |
