Choosing Proper Wire Size - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-22-2008, 01:58 AM   #16
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by Holden McGroin View Post
Use the following guide:
15 amps = 14ga.
20 amps = 12 ga.
30 amps = 10ga.
40 amps = 8 ga.
50 amps. = 4-6 ga.
That listed is for copper wires but however with alum wire it will change a bit.
alum size
30 amp = 8 ga
40 amp = 6 ga
50 amp = 6/4 ga size
60 amp = 4 or 2 [ some case you can snag on #3 but this is kinda rare bird on this size]
Please note on the latter two you may wondering why i listed two size due depending if you are running NM or SE cable and code cycle it will fall into two spots the larger one is in effect on 08 codes due NM and SE have to use 60C rating the older code can use 75C rating but however some breaker are only rated to use 60C termations so watch out on this part. { ditto with copper wire verison as well }
[ A good inspector will nail on this one if he can catch it ]
Merci,Marc
Tags
wire size
Wire size dc49ers Electrical 17 03-30-2008 04:45 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
Wire size for distance Question fburke Electrical 4 07-28-2007 10:29 AM
Wire size for Central Air mwtuck HVAC 2 12-01-2006 06:06 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
