Chewed Wire Insulation. Is There An Approved Repair? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2012, 02:36 PM   #1
Chewed wire insulation. Is there an approved repair?
Merry xmas everyone!
I recently found a section of wire that appears to have been chewed by a rodent. Normally I would just replace the section of wire. Unfortunately, this section goes into the wall and runs to the bathroom on the other side. I am trying real hard not to open up anything in the bathtoom and leave it undisturbed (I promised the wife I
wouldnt touch the bathroom). There doesnt seem to be any room to place a junction box either.
I work on cars for a living and have been repairing car wiring for a long time, especially rodent chewed wires. Of course they are different as far as current and voltage goes but seeing that the conductor on the wire in question is not damaged, could I use some ghick shrink tube to repair the damage? Im not sure what is legal as far as code goes but I can be sure the conductor will be covered when im done. I can disconnect the wire on the open side of the wall to slide the shrink tube over it as it terminates in an outlet box.
Maine1 is offline   Reply With Quote
Old 12-25-2012, 03:11 PM   #2
Rewards Points: 332
First off, address the rodent problem first. Otherwise, you'll be fixing more wires.
If the inner insulation isn't chewed, you can use electrical tape or heat shrink tubing. Maybe even a piece of split loom tubing.
Would it be possible to twist a new wire onto the end of this one in the bathroom and pull it through to a junction location?
sgip2000 is offline   Reply With Quote
Old 12-25-2012, 03:22 PM   #3
It feels like the wire is probably stapled along the way to the bathroom switch.
I can see the copper for the hot wire (black) but it is intact. I cant imagine why protecting it with shrink tube and making sure its secure would cause any problems. I will wait to hear the general consensus on this first.
Thanks!
Old 12-25-2012, 04:01 PM   #4
Electrical Contractor
kbsparky's Avatar
Heat shrink would be an appropriate repair
-KB
Old 12-25-2012, 04:03 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Thanks!
Agreed!
sublime2 is offline   Reply With Quote
Old 12-25-2012, 10:04 PM   #6
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Fix the rodent problem cover with heat shrink tubing and get some flexible metal conduit with red heads installed on each end. They sell it in many sizes. That will protect the wire from future rodent damage. I use it wherever there is a rodent problem and I have to make a repair. I would also see if you can replace the whole wire if you can.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 12-26-2012, 08:28 AM   #7
joed's Avatar
Rewards Points: 12,438
In order to use heat shrink tubing you need to disconnect one end of the cable.
Old 12-26-2012, 08:45 AM   #8
rrolleston's Avatar
Also maybe you could abandon the wire and fish in some MC? If it looks like that where you can see it. It's possible it looks like that where you can't see it too.
The Following User Says Thank You to rrolleston For This Useful Post:
joecaption (12-26-2012)
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
