?? To Check Power Status In Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 02:33 PM   #1
?? to check power status in subpanel
What would I purchase to check to make certain there was no power going to breakers i was going to work on in a subpanel? i just want an added layer of protection to make sure i an mot working with live wires.
thanks
rs2004 is offline   Reply With Quote
Old 04-19-2011, 02:43 PM   #2
rditz's Avatar
a simple "no contact" tool would be a pencil type tester. you can get these at any home improvement store.
you hold and point the tip to the wire you are checking.. once you have the tester in range, it will flash and beep (depending on the type).
rod
rditz is offline   Reply With Quote
Old 04-19-2011, 03:04 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Never trust your life to a no contact tester!
They have there place in troubleshotting, but not to bet your life on them.
You need a wiggy style tester, or a multi meter.
The Following User Says Thank You to jbfan For This Useful Post:
HouseHelper (04-19-2011)
Old 04-19-2011, 06:39 PM   #4
Scared Electrician
Saturday Cowboy's Avatar
seconded no contacts are dangerous to DIYers, Proper technique to prove power is off is to use a DMM.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-19-2011, 07:04 PM   #5
I=E/R
a7ecorsair's Avatar
thanks
Since you are asking the question about what to use to test for power to a breaker is sounds like you do not have a lot of experience in this area. Get yourself a multimeter, it doesn't have to be a pro model.
So first thing, does the sub panel have a main disconnect? This would be a large breaker at one end of the bus bars. If so, you have double protection. Your main panel that feeds the sub will have a breaker to cut power to the sub and if the sub has a disconnect that too will cut power, but only to the bus bars. The feed lines have to be turned of at the main. If you really want to make sure you've cut power measure the power feed lines where they connect to the sub with your new meter. You should read 240 volts. Then go to your main panel and turn off the breaker that protects the sub. Then go back to the sub and see if the 240 volts is gone.
a7ecorsair is offline   Reply With Quote
Old 04-19-2011, 07:52 PM   #6
" Euro " electrician
frenchelectrican's Avatar
rod
Rod.,
I will never trust the NCV tester 100% of the time sometime they can get a fause signal as well so use the wiggy or DVM meter and double check by check with verify source then test what need to be done and go back and double check to make sure the meter is not wacked or anything.
All the years I always carry at least two test meters or more in case one not working I get second one to verify it.
Merci,
Marc
Inverter powering a subpanel codename47 Electrical 4 03-22-2011 12:03 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 10:45 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 10:56 PM
