Check My Work? (Drawing) - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 12:50 PM   #1
Rewards Points: 81
Check my Work? (Drawing)
Im planning to put in a ceiling fan in a bed room where there is currently only a switched outlet and no ceiling box. I have an end of run outlet that is near my switch location and that I can access from the attic. Just wondering if someone can make sure that my wiring plan looks correct in the drawing below. Im going to pull 14-2 from the existing outlet into the attic and put it into a junction box. From there I will bring the black wire from a piece of romex to the bottom screw of a switch, run the white wire (with black tape on the ends) back to the junction box and then connect with a wire nut to the black lead of the fan. I will connect the white from the fan to the white from the line I brought from the existing outlet. Finally, I will bring a piece of romex down to a box in the wall for a flat TV where I will put a 1 gang box and outlet. All grounds will be connected with a wire nut in the box. Look good?
Many thanks!
BaconK5 is offline   Reply With Quote
Old 12-09-2010, 12:58 PM   #2
Rewards Points: 320
Almost. Looks like you correctly recolored the white wire for the switch loop black, however you should always leave on the white (even though it is recolored black) and return on the black. That way the fixture is not hooked up to two white wires.
teamo is offline   Reply With Quote
Old 12-09-2010, 01:00 PM   #3
Rewards Points: 81
Interesting. Ive ready just the opposite but what youre saying makes sense. If I swap those two, should I still put the hot on the bottom screw of the switch? Does it matter or is that just best practice?
Old 12-09-2010, 01:20 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
It does not matter if you use the top or bottom screw.
jbfan is online now   Reply With Quote
Old 12-09-2010, 05:16 PM   #5
joed's Avatar
Rewards Points: 12,866
Code in fact requires the black to be the switched wire. Which screw does not matter. You simply need to swap the black and white in the junction box.
Old 12-09-2010, 06:01 PM   #6
Rewards Points: 1,192
Once you get into adding additional outlets(switches,receptacles,ect.)you get into having to use AFCI breakers,Especially in a bedroom.Check your local codes.
bobelectric is offline   Reply With Quote
Light wont work after changing switch Duncan25 Electrical 8 06-27-2010 11:02 AM
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 11:53 AM
HVAC duct work radiates 60Hz Mike in Arkansas Electrical 3 01-01-2010 07:29 PM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
