Check My Wiring Plan - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-07-2013, 09:42 PM   #16
Thanks Marc. I was wondering the same thing - are overhead outlets such as I've wired required to be on a GFCI circuit? I wired them that way so that I can use a specific type of light (which I can reposition as needed) and the extra outlets are always useful. I'll probably just bite the bullet and install the GFCI breaker. The problem is that my main panel is full (especially the neutral/ground bar), and the panel doesn't have a mains breaker to shut the whole thing off - so I'm reluctant to mess around in there. Thanks everyone for all the help. - mark
adis is offline   Reply With Quote
Old 07-07-2013, 09:52 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Before you do anything more I will get ahold couple guys which they live in that state and they can give me some info to pass it to ya to see where the codes stand for the luminaire requirement.
Merci,
Marc
Elaborate Plan for wiring my theater lighting danielrg Electrical 21 04-05-2013 05:26 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Wiring Plan Check mark_anderson_u Electrical 3 12-06-2010 09:59 PM
Please double check my tstat wiring firedogut HVAC 1 10-14-2009 04:47 AM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 09:56 PM
