Cheapest Wire Molding? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2008, 06:27 AM   #1
cheapest wire molding?
I need a 15' run of wire across a ceiling, where can I get the cheapest good wire molding please?
mikehende is offline   Reply With Quote
Old 06-06-2008, 07:25 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
It's only 15'. Price should not be an issue.
Use what ever is available.
Speedy Petey is online now   Reply With Quote
Old 06-06-2008, 07:34 AM   #3
where can I get them locally? I checked the Home depot site, nothing?
Old 06-06-2008, 08:00 AM   #4
All big chain Departments stores sells them in the electrical department. They don't have everything they sell on there websites. I beleive they come in 5-6' ft sections, and they also sell all the other accessories to go with it.
helpless handyman is offline   Reply With Quote
Old 06-06-2008, 08:14 AM   #5
Just called a local True Value Hardware here, they have it but it's "stick-on", I am not sure about this, don't want it dropping off the ceiling. I'll check Home depot or Lowes to see if they have anything which screws or nails on.
Old 06-06-2008, 10:10 AM   #6
Rewards Points: 266
There's a company that is called "Wiremold." They make both metal and plastic surface raceways. You can get all sorts of fittings, boxes, etc that go along with it. I know HD carries it. I think it is expensive for what it is, but it works in some cases. If looks are not an object, I would use EMT or ENT conduit and the appropriate fittings. Much less expensive.
junkcollector is offline   Reply With Quote
Old 06-06-2008, 10:26 AM   #7
This wire is to be run across my living room ceiling so I that is why I don't want to take a chance on a stick-on molding, I will look into all options.
Old 06-06-2008, 10:45 AM   #8
joed's Avatar
Rewards Points: 12,446
You should be able to run some screws through the stickon to hold it up.
Old 06-06-2008, 10:54 AM   #9
I'll go take a look at it tomorrow to see if that's possible.
Old 06-06-2008, 11:48 AM   #10
Power Gen/RS Engineer
Rewards Points: 566
I've installed some but very little of this product. They sell two-hole "top hat" straps for securing to walls/ceilings however if Joe is right on this (and he probably is) that approach will look much better. My local HD, Lowes and Ace all carry the Wiremould brand incl. every box/fitting available. In fact, I noticed that most of those stores that I've been to in other localities also carry them. Maybe yours are simply hiding it.
As someone else mentioned, the stuff is NOT cheap. Even the accessories are pretty steep.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 10:12 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
