Cheap Flip Flop Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 01:18 AM   #1
What is the cheapest way to switch a single wire (runs 110v 4 amp load) on for 10 minutes, and then off for 10 minutes indefinitely ? The cheapest purpose built thing i could find was $100.
ob2s is offline   Reply With Quote
Old 07-24-2012, 05:36 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
These multifunction relays and a base would be around $51
relay
You could set it to repeat cycle mode. I believe these particular timers call it the "flicker" mode
wirenut1110 is offline   Reply With Quote
Old 07-24-2012, 05:58 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
This one does every 15 mins.... but only cost 12 dollars... Just google them, I saw other ones that would work as well....
Old 07-24-2012, 09:32 AM   #4
Flicker is indeed the mode I need. And I will look for the cheaper tork, thanks again !
