Chasing A Wall For Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 03:21 PM   #1
Chasing a wall for wiring
I want to chase an internal brick wall to run a spur off an existing electrical socket to the other side of a room to create another socket. How deep do I need to chase the wall. Also can I just cement the cable in or do I need to use trunking ?
Many thanks for any help.
Rich
kentucky bucket is offline   Reply With Quote
Old 08-17-2009, 03:32 PM   #2
If you need to notch the brick (block? mortar?), it must be 1 1/4" deep.
Also, it is supposed to be UF cable..... but that's only a technical foul in my opinion. A little mortar isn't going to damage the cable..
220/221 is offline   Reply With Quote
Old 08-17-2009, 04:23 PM   #3
Thanks for the reply.
I have been on many forums to find out the correct depth and I have seen various measurments from 60mm to 20mm. I also wanted to use mortar to seal the cable in, do I need a conduit to fix the cable into the channel first or will the cable hold while the mortar is applied over it and when it is drying ?
Old 08-17-2009, 05:10 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
How about telling us what country you are in?
From your name we'd think the US, but from your writing I'd say the UK.
This DOES make just a bit of difference.
Old 08-17-2009, 07:49 PM   #5
You don't need conduit in most cases. A cable will hold itself in the properly sized notch. If not, find something that will hold it in place until the mortar is applied.
Old 08-18-2009, 01:58 PM   #6
Hi Speedy Pete, I'm from the UK Sorry for confusion.
I have chased the wall to a depth of 30mm and this depth appears to be deep enough to allow a conduit to fit well inside the chanel without protruding.
Good advice 220/221.
Many thanks for your help.
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 12:17 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Wall cap for masonry wall cliffslocal Building & Construction 1 04-01-2009 02:59 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
