Charging Power Pack - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 07:42 PM   #1
charging power pack
I built a portable 12v power pack using a agm battery. the +/- wires go from the battery to a toggle switch, then to a cigarette plug.
I currently charge using trickle charger.
Can I use a 110V usb plug for a cell phone, with a usb cable that goes to a usb capable cigarette plug to charge the battery? the circuit is open if I turn the toggle switch on so the incoming current could make it to the battery. Will this work?
kobbs is offline   Reply With Quote
Old 11-29-2011, 07:53 PM   #2
Rewards Points: 756
I think what you are trying to do is charge the battery using a cell phone charger. Is that correct?
No. You can't do that. USB is only rated at 5 volts and 1/2 amp, max.
Find the proper charger for your AGM battery.
AandPDan is offline   Reply With Quote
Making a waterproof/weatherproof enclosures for a network camera & its power hub snowfall Building & Construction 0 05-02-2011 10:14 AM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
