Charging A L-ion Phone Battery....? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2015, 02:53 PM   #1
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,640
Charging a L-ion Phone Battery....?
Hey guys...
I had to get a new phone.... it came with just an AC charger and I am wondering if I can use my former car charger on it's battery also.
The battery in the phone has the following info: All DC of course.
Li-Ion 900 MAh
Nominal Voltage 3.7V
Limited Charge Voltage 4.2
The AC charger for this battery has an output of 5.0V and 700MA.
My old car charger has an output of 5.0V but only 550MA.
Does anyone understand battery charging...
and can I use, or will it hurt, the new battery to use the car charger which is 5.0V BUT only 550MA (as the AC charger that came with it can supply 700MA.)
Maybe it will just charge it slower, which is fine, but I don't want to use it if it will screw up the battery.
TIA
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 05-19-2015, 03:06 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Assuming they both have a mini USB plug, it will work fine. Most car chargers have a slower charge rate vs a AC charger.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following 2 Users Say Thank You to rjniles For This Useful Post:
micromind (05-19-2015), MTN REMODEL LLC (05-19-2015)
Old 05-19-2015, 03:11 PM   #3
RJ... Thank ya..... Yes they both are mini-usbs.
Just curiosity, any difference if they were the RCA plugs. (You can tell I know NOTHING about electronics)
Old 05-19-2015, 04:21 PM   #4
Oso954's Avatar
Rewards Points: 772
RCA and other single pin plugs are dumb plugs. That's why you have to be so careful matching the adapter outputs.
USB (universal serial bus) plugs are smart plugs. They have industry standard protocols that can be used to control or limit the power supply.
Oso954 is online now   Reply With Quote
Old 05-19-2015, 04:23 PM   #5
A "Handy Husband"
rjniles's Avatar
mini USB have a standard format and voltage that all manufacturers have agreed to. Older plug designs were specific to each maker; even if they were to fit the voltage may be wrong.
Charging more than one ATV battery at the same time. ise27 Automotive Repairs 10 12-11-2013 04:06 PM
Charging battery while using it vs charging till empty will this affect battery life? jratftcc Electrical 2 04-01-2013 11:41 PM
Laptop battery litium Ion batter not charging. Modrisco PC Repairs & Upgrades 4 09-20-2012 10:37 PM
battery not charging nykou PC Repairs & Upgrades 1 08-31-2012 07:58 AM
