-   -   charging flooded cell in a basement? (http://www.diychatroom.com/f18/charging-flooded-cell-basement-168147/)
bubbler 01-03-2013 02:08 PM
I know this is not electric related specifically, but I thought this was a good forum to ask--
I have a friend who is installing one of those Basement Watchdog sump pump's with a battery backup.
I was very surprised to see that they use a flooded cell battery--it was always my understanding that those types of batteries should never be charged in an enclosed space, especially indoors, due to the potential for hydrogen build up and explosion.
I pointed this out to my friend and he started to read the instructions, with what I think are some almost comical suggestions from them like--"fan the battery with a piece of cardboard to disperse hydrogen"...
Anyone have any thoughts on this? Is it safe, or questionable? He's got a 90% finished basement (raised ranch) and this will be getting installed in the 10% that is unfinished and houses his oil furnace and water heater--i.e. appliances with flame and spark! :eek:)
Bondo 01-03-2013 02:24 PM
Ayuh,.... In my experience with batteries, I think it's a problem in yer mind, but not in the real world...
While batteries do gas off while chargin', it ain't that much gas...
ddawg16 01-03-2013 03:14 PM
Can't be any worse than what comes out of me......
With that said....if the basement is air tight....yes, you could have a problem. But as long as there is some air exchange, the hydrogen gas venting should be a minimum.
Note....he needs to make sure he uses the right charger....he does not want one that charges the battery so much that it starts to boil....the battery won't last long.
bubbler 01-03-2013 03:51 PM
This is a "system", so it's a matched charger, pump and battery. It looks like this particular version of the system will only charge at a rate of 500mA-1A, so not too bad, I suppose the chance of boiling or out gassing very much will be low. They have a larger system, called "Big Dog" (or something) that I see has a 20A charging rate. I don't know what battery they specify for that, might be a sealed type. There must be tens of thousands, if not more, of these systems out there operating... so I'm guessing it's reasonably safe or would be recalled...
I have my own cobbled setup--A large deep cycle battery connected to an inverter. When I need to top off the battery every few months, or re-charge after an outage, I will manually take the battery outside and charge it.
Having been indirect witness to an exploding car battery, I would imagine an explosion inside of a 5'x10' furnace room could be pretty bad, particularly if a person happens to be in there working when it happens. Both my friends system, and my cobbled system, have the battery stored inside a battery box--so at least that minimized the potential destruction as long as the cover is on whenever final connections are made.
ddawg16 01-03-2013 04:13 PM
5' x 10'? Thats pretty small......
I've had a battery explode near me.....we were lucky....it just cracked the case.....no one was hurt....I've 'heard' of worse.
The battery box is a good idea.
