Chaning A Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2008, 11:24 AM   #1
Chaning a plug
I bought an older magic chef oven and it has a 3 prong plug and my place needs a 4 prong plug. i bought the plug and need to know how to hook it up because it has a extra wire.
dyson4000 is offline   Reply With Quote
Old 08-27-2008, 01:18 PM   #2
joed's Avatar
Rewards Points: 12,852
You need to change the entire cord on the oven. You manual from the oven or the manufacturer web site should have instruction how to do it.
What you need to do is look where the current cord attaches. The red and black will be the same. The white and green need to be split apart to separate connections. There is probably a jumper in the stove connecting them together now.
Old 08-27-2008, 06:40 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
On the back of the oven, take the cord cover off and you should see a 3 terminal block. The outer 2 should be the 'hot' terms, and the middle the neutral. See if there is a jumper or bonding strap between the center term and the frame/casing of the oven. You'll want to remove that strap/jumper. If there is a screw holding that strap to the frame, use it to hook up your 4th wire, which is a ground wire.
GFI Plug Troubleshooting bryanchr Electrical 4 08-22-2008 05:28 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 01:27 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 09:03 PM
