Old 06-11-2012, 05:05 PM   #1
Changing a ywo switch bathroom outlet
Trying to change switch in bathroom. Pretty sure I connected wires correctly. One switch works, but the other switch keeps tripping the breaker. The house was built in the 30's, still has original wires. Connected 2 hot wires on right side of switch and 2 wires on left. There is no ground wire inside box. Help before I go crazy!!!
Bobby B is offline   Reply With Quote
Old 06-12-2012, 12:34 AM   #2
Is this a 4-way switch, meaning you're able to control a lamp fixture from 3 or more different locations? Odd for bathroom.
What are the wire colors, and please describe this switch that has two screws each on either side.
Old 06-12-2012, 02:23 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Most likely you may have oringal tube et knob wiring if so this will get very tricky to deal with it.
Before we can comment more on this can you post the photo in the fourm so we can able determed what it need to be done?
Merci,
Marc
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 10:20 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Switch outlet in bathroom odale Electrical 7 12-11-2009 08:04 PM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 09:08 AM
