Changing Wire Gauge Larger To Smaller - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 04:41 PM   #1
Changing wire gauge larger to smaller
Ignore the title of this thread I am informed of not doing this.
I am finishing an area in the back of my garage where there are existing washer dryer hookups to create a laundry room with access from inside the house. This laundry area will be walled off from the rest of the garage. Can I use the circuit from the adjacent dining room to connect in the new laundry room 4 ceiling recessed lights and 2 outlets- not the washer or dryer? I have 12/2 romex running from an existing outlet in the adjacent dining room- which is the first device on this circuit- into a 2 gang 32 cu inch box where 2 wall switches for the new laundry ceiling lights will be wired, the 2 laundry outlets and 1 additional existing dining room outlet.
If not is the following scenario permissable? There will be a junction box in the laundry room with 12/3- white powers the washer and red feeds into the garage-2 outlets and an outdoor motion sensor light. Can I tap into the red to power the laundry recessed cans and 2 outlets?
maurice53 is offline   Reply With Quote
How do I provide power to a plug when changing single pole 3 wire to 3-way switch Morris12 Electrical 4 01-05-2011 08:41 PM
16 gauge wire to an 8 gauge wire jbvw Electrical 5 11-28-2010 10:21 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Standard gauge for household electrical wire tripower Electrical 2 09-21-2008 11:42 PM
