06-11-2012, 05:08 PM
#1
Changing a two switch bathroom outlet
Trying to change switch in bathroom. Pretty sure I connected wires correctly. One switch works, but the other switch keeps tripping the breaker. The house was built in the 30's, still has original wires. Connected 2 hot wires on right side of switch and 2 wires on left. There is no ground wire inside box. Help before I go crazy!!!
06-11-2012, 05:32 PM
#2
Licensed Electrician
The switch you are having trouble with has four terminals?
How many terminals did the switch that came out of there have?
This sounds like a 4way switch you installed and you are shorting the circuit out hot to neutral, but can't be sure unless you answer those questions.
Location...Location...Location
06-11-2012, 05:34 PM
#3
E2 Electrician
The thing is, He took out two switches, reinstalled two switches... how bad could this be?  must have pinched a wire when reinstalling...
06-11-2012, 05:40 PM
#4
We just had a guy on here saying there were 21 (yes, twenty-one) two pole switches in his house.
It sounds to me that he put the neutrals to one side and the hots to the other side of a 4way switch.
06-11-2012, 06:07 PM
#5
E2 Electrician
Wow. but believable.
06-11-2012, 06:09 PM
#6
E2 Electrician
After rereading the original post, I think you may be correct.
06-11-2012, 07:27 PM
#7
Average Joe/ex-Navy IC3
Can you post pictures of said switch and the wiring.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
06-11-2012, 07:39 PM
#8
Licensed Electrical Cont.
I think it is a stack switch.
Thing is, the left side and the right side of the switch means nothing, although most lay people think this is an important description.
Let the guessing game continue.
06-11-2012, 07:41 PM
#9
Good thought...didn't think of that option.
06-11-2012, 07:46 PM
#10
E2 Electrician
totally off topic, but best problem I ever found was a circuit that was fed from two different breakers, turned out someone installed a 3way over single pole and never broke out the common tab... that one took some time to find.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
