Changing a two switch bathroom outlet
Trying to change switch in bathroom. Pretty sure I connected wires correctly. One switch works, but the other switch keeps tripping the breaker. The house was built in the 30's, still has original wires. Connected 2 hot wires on right side of switch and 2 wires on left. There is no ground wire inside box. Help before I go crazy!!!
The switch you are having trouble with has four terminals?
How many terminals did the switch that came out of there have? This sounds like a 4way switch you installed and you are shorting the circuit out hot to neutral, but can't be sure unless you answer those questions. |
We just had a guy on here saying there were 21 (yes, twenty-one) two pole switches in his house.
It sounds to me that he put the neutrals to one side and the hots to the other side of a 4way switch. |
Can you post pictures of said switch and the wiring.
I think it is a stack switch.
Thing is, the left side and the right side of the switch means nothing, although most lay people think this is an important description. Let the guessing game continue. |
totally off topic, but best problem I ever found was a circuit that was fed from two different breakers, turned out someone installed a 3way over single pole and never broke out the common tab... that one took some time to find. |
| All times are GMT -4. The time now is 11:04 AM. |
