Changing Timer Switch To Standard Switch With Neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2013, 10:35 AM   #1
changing timer switch to standard switch with neutral
I want to change an old timer switch for an outside light (which isn't working right) with a standard on-off light switch. Problem is, the timer switch has 2 black wires, and no neutral, and I don't see a neutral wire in the box for that particular circuit. Note that this switch is located in a large box with 4 other circuits for other lights, and there are white wires there for those other circuits. Should I connect a white wire from the on-off switch to one of those white wires ?
johnnyboy_808 is offline   Reply With Quote
Old 06-10-2013, 10:50 AM   #2
Licensed electrician
Rewards Points: 1,258
A standard switch does not use or need a neutral.
Old 06-10-2013, 11:04 AM   #3
Ah ok - easy then. Thanks !
Bathroom timer switch clydesdale Electrical 2 12-12-2012 01:39 PM
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 06:20 PM
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 03:48 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
