Changing Three Way Switch To Two Way Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 06:10 PM   #1
Post
Changing three way switch to two way switch?
Hi,
I have a three-way switch whereby one switch is at the top of the stairs, one at the bottom and a third in the basement rec room - they all work the light to the staircase down to the basement and a light over the doorway in the rec room. I want to change this so the one at the top of the stairs and the one at the bottom work the light to the stairs but, and this is the fun part, the one in the rec room works the light over the doorway. is this possible and how do I do it?
Ricky&theblues is offline   Reply With Quote
Old 09-28-2010, 01:19 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
It is possible, but only with about 50 questions.
Where does the feed come from?
Are the walls open to get to the switches and lights?
Can you use romex in your area?
What advange do you hope to gain from all the frustration and work?
There will be other questions as these are answered.
jbfan is online now   Reply With Quote
Old 09-28-2010, 04:20 PM   #3
Hi Jimmy ... the band plays a few of your songs
Where does the feed come from? Not sure ... the top of the stairs I think.
Are the walls open to get to the switches and lights? No.
Can you use romex in your area? What is romex?
What advange do you hope to gain from all the frustration and work? The rec room is now turned into a suite - so wewould love independant control down there of the doorway light.
Hope this helps.
R
P.S. "He Went To Paris" is a great song by Jimmy.
Old 09-28-2010, 05:17 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
I will try to be gentle: If you do not know what Romex is, you are over your head. Even if the existing wiring configuration is such that it can be done without rewiring, you will need to have a better understanding of the circuit.
BTW, the middle switch in you existing setup (if you have described it correctly) is called a 4 way switch. (Makes as much sense as calling a 3 way a 3 way, but that is what it is called.)
Coastal South Carolina
In-Line Switch on Hard Wired Fixture 1sthome1068 Electrical 2 08-29-2010 07:42 AM
Switch now controls large area... froddan Electrical 5 12-06-2009 10:04 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Changing Light Fixture - Way too many wires and light wont switch off marapapa Electrical 3 01-13-2006 01:16 PM
