Changing A Switched Receptacle To A Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 10:30 PM   #1
changing a switched receptacle to a ceiling fan
I'm installing a ceiling fan in a bedroom which currently has a switch that controls a receptacle. I want the existing switch to control the fan while keeping constant power to the receptacle. The switch currently has a 14/3 and 14/2, with the red and black from the 14/3 hooked to the switch. Can I wire the 14/2 from the fan to the switch so it works the fan?
Thanks,
Travis
travisc is offline   Reply With Quote
Old 06-08-2010, 11:53 PM   #2
Electrical Contractor
kbsparky's Avatar
Yup, shore can. Just connect all the existing black and red wires together in your switch box, with a tail to the fan control switch.
Install your 14-2 from the fan control to the fan, and you should be good to go.
-KB
Questions About Changing GFCI receptacle to a normal three pronged outlet LYTTONJ Electrical 11 05-04-2011 03:23 PM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 01:53 PM
Rewiring a switched receptacle to recessed lights b-boy Electrical 4 03-03-2007 08:01 PM
changing drop ceiling to normal ceiling acoustic_bum General DIY Discussions 7 01-16-2007 08:52 AM
